controlleur with IOS 8.2.170
Dhikra Marghli
Level 5
Level 5
Hello
i have a controlleur with IOS 8.2.170
and AP 1815i
so what ios that i can downlod in controlleur that allow work to 1815i OR  what IOS in 1815i that allow work with controlleur 8.2.170 ????,,
please , i need a help about this ^problem !!
thanks in advance
you need 8.3.112.0 or higher version on WLC .
Dont forget to rate helpful posts
6 Replies 6
Ric Beeching
Level 7
Level 7
Check the compatibility matrix here:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#wp99531
**Edit** Can't even read my own link. As Sandeep said in the other post you put up, you need code 8.3.112.0 minimum to get it to work.
Please rate helpful / correct posts
vesrion ap 1815i
AP28AC.9E89.3E10 uptime is 0 days, 0 hours, 55 minutes
Last reload time : Mon Feb 11 11:35:09 UTC 2019
Last reload reason : unknown
cisco AIR-AP1815I-I-K9 ARMv7 Processor rev 5 (v7l) with 1015956/821884K bytes of memory.
Processor board ID FGL2209B3S8
AP Running Image : 8.3.111.0
Primary Boot Image : 8.3.111.0
Backup Boot Image : 8.3.111.0
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : 8edf74e05d634a962e683454e8fc1be2
NSS FW version : not available
--More-- [*02/11/2019 14:48:57.4599]
[*02/11/2019 14:48:57.4599] CAPWAP State: Discovery
[*02/11/2019 14:48:57.4699] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*02/11/2019 14:48:57.4699] Discovery Response from 1.1.1.111
[*02/11/2019 14:48:58.0000]
[*02/11/2019 14:48:58.0000] This AP model is supported by controller version newer than 8.3.15.100!
[*02/11/2019 14:48:58.0000] Discovery response from MWAR 'Cisco_c8:e9:71'running version 8.2.170.0 is rejected.
[*02/11/2019 14:48:58.0000] Failed to decode discovery response.
[*02/11/2019 14:48:58.0000] CAPWAP SM handler: Failed to process message type 2 state 2.
[*02/11/2019 14:48:58.0000] Failed to handle capwap control message from controller - status 4
[*02/11/2019 14:48:58.0000] Failed to process unencrypted capwap packet 0x21a7000 from 1.1.1.111
[*02/11/2019 14:48:58.0000] Failed to send capwap message 0 to the state machine. Packet already freed.
[*02/11/2019 14:48:58.0000] IPv4 wtpProcessPacketFromSocket returned 4
Base ethernet MAC Address : 28:AC:9E:89:3E:10
Part Number : 0-0000-00
PCA Assembly Number : 074-105850-02
PCA Revision Number : 0
PCB Serial Number : FOC22063ABK
Top Assembly Part Number : 074-105850-02
Top Assembly Serial Number : FGL2209B3S8
Top Revision Number : A0
Product/Model Number : AIR-AP1815I-I-K9
version controlleur :
~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.02.11 13:54:14 =~=~=~=~=~=~=~=~=~=~=~=
show tech-support
---------------Show boot---------------
Primary Boot Image............................... 8.2.170.0 (active)
Backup Boot Image................................ 8.2.170.0
---------------show time---------------
Time............................................. Mon Feb 11 13:53:38 2019
Timezone delta................................... 0:0
Timezone location................................
---------------Show Inventory---------------
System Inventory
Burned-in MAC Address............................ 00:0C:29:C8:E9:71
Maximum number of APs supported.................. 200
---------------Show udi---------------
NAME: "Chassis" , DESCR: "Cisco Wireless Controller"
PID: AIR-CTVM-K9, VID: V01, SN: 97OOPOS3PDR
---------------Show sysinfo---------------
System Information
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.170.0
RTOS Version..................................... 8.2.170.0
Bootloader Version............................... 8.3.15.96
Emergency Image Version.......................... 8.2.170.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_c8:e9:71
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 1.1.1.111
IPv6 Address..................................... ::
System Up Time................................... 0 days 0 hrs 12 mins 5 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... TN - Tunisia
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Small
---------------Show advanced backup-controller---------------
Backup Controller Configuration
AP primary Backup Controller ....................
AP secondary Backup Controller ..................
---------------Redundancy Information---------------
--More-- or (q)uit
Redundancy Mode ................................. SSO DISABLED
Local State...................................... ACTIVE
Peer State....................................... N/A
Unit............................................. Primary
Unit ID.......................................... 00:0C:29:C8:E9:71
Redunadancy State................................ N/A
Mobility MAC..................................... 00:0C:29:C8:E9:71
Redundancy Management IP Address................. 0.0.0.0
Peer Redundancy Management IP Address............ 0.0.0.0
Redundancy Port IP Address....................... 0.0.0.0
Peer Redundancy Port IP Address.................. 169.254.0.0
So what ios can upgrad controller that allow AP work witk controler or virs vers ????,
what solution for upgrade IOS in AP or controlleur?????????,
thanks in advance
Ok , i  ask  if this version 8.3.112 can upgrad in WLC virtual ???????,
thanks in advance
Leo Laohoo
Please refer to CSCuw56127 and change the controller country settings to either Egypt or Israel.
