Convert 1815 back to ME
I have a Cisco 1815 that was purchased not too long ago and originally it was joined to a WLC 2504 controller. However, now I want to move it to a different site and want to convert it back to Mobility Express controller. I have followed a few guides online but the AP still starts in a controller mode.
The AP is on a different subnet, different location altogether now by the way, so it is unable to see the original controller.
AP Running Image     : 8.7.106.0
Primary Boot Image   : 8.7.106.0
Backup Boot Image    : 8.5.120.0
Primary Boot Image Hash:
Backup  Boot Image Hash:
AP Image type    : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : f1e77cf8ab1e497b17ad53633866ea42
NSS FW version : not available
Any suggestions, please?
7 Replies 7
 According to the output you shared, the AP is actually Mobility Express.
 AP Image type : MOBILITY EXPRESS IMAGE AP Configuration : MOBILITY EXPRESS CAPABLE
What is not right?
-If I helped you somehow, please, rate it as useful.-
If I do show run, I still see this:
AP Name                    : AP-03-Leeds
Admin State                : Enabled
AP Mode                    : FlexConnect
AP Submode                 : None
Reboot Reason              : Reload command
Primary controller name    : main-wlc
Primary controller IP      : 172.11.11.1
Secondary controller name  :
Secondary controller IP    :
Tertiary controller name   :
Tertiary controller IP     :
AP join priority           : 1
IP Prefer-mode             : IPv4
CAPWAP UDP-Lite            : Unconfigured
Last Joined Controller name: WLC2504
DTLS Encryption State      : Disabled
Discovery Timer            : 10
Heartbeat Timer            : 30
CDP State                  : Enabled
Watchdog monitoring        : Enabled
IOX                        : Disabled
RRM State                  : Enabled
LSC State                  : Disabled
SSH State                  : Enabled
AP Username                : dmitry
Session Timeout            : 300
Extlog Host                : 0.0.0.0
I am unable to browse the AP via it's IP address and there is no CiscoAirProvisioning SSID visable either.
 Try "clear capwap private-config".
Thank you... Afraid that command is not available. Any other suggestions?
reset the AP:
To reset the AP to the default factory-shipped configuration, keep the mode button pressed for less than 20 seconds.
Dont forget to arte helpful posts
If AP were lightweight should be there.
 I'd go for reset the AP to factory default and start over.
 Follow this guide and you should be good.
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/82/user_guide/b_ME_User_Guide_82/appendix.html#task_330D7AD89F974001BEF10985059485DF
Going to get the AP back to our office as I am not on site to do it. Thanks for your help.
