convert air-ap1852i-k9C
Lextercisco
Is it possible convert an air-ap1852i-k9C in a capwap to connect it to a wlc3504?
Thanks to all
V.
Haydn Andrews
Yes
the 1852 is compatible with the 3504 WLC
See the compatibility matrix here:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Yes I nknow, but in this case I talk about 1852C the "wlc".
I need to now if it is possible convert it from wlc to capwap ap and than join it to wlc3504
All you need to do is change the ap type to capwap by logging to AP cli and use the command "ap-type capwap". For the instruction on how to go to AP cli from controller mode on ME and commands to covert AP please check the section "Converting an AP from Mobility Express to CAPWAP Type" in the document below:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/82/user_guide/b_ME_User_Guide_82/appendix.html
Yes, you can convert 1852 ME  to CAPWAP and join the 3504 WLC.
1. connect to the AP console port
2. Go into AP Cisco Shell:
(Cisco Controller) > apciscoshell
3.  Log back into the AP again
Go into enable mode:
(Cisco Controller) > en
4. Change to CAPWAP mode:
(Cisco Controller) > ap-type capwap
The AP will reboot one more time, then it will be in CAPWAP mode.
***Please rate all useful posts***
Jagan
