02-08-2019 03:23 AM - edited 07-05-2021 09:49 AM
Is it possible convert an air-ap1852i-k9C in a capwap to connect it to a wlc3504?
Thanks to all
V.
02-08-2019 03:27 AM
Yes
the 1852 is compatible with the 3504 WLC
See the compatibility matrix here:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
02-08-2019 03:49 AM
Yes I nknow, but in this case I talk about 1852C the "wlc".
I need to now if it is possible convert it from wlc to capwap ap and than join it to wlc3504
02-08-2019 05:55 AM
02-08-2019 08:45 AM
Yes, you can convert 1852 ME to CAPWAP and join the 3504 WLC.
1. connect to the AP console port
2. Go into AP Cisco Shell:
(Cisco Controller) > apciscoshell
3. Log back into the AP again
Go into enable mode:
(Cisco Controller) > en
4. Change to CAPWAP mode:
(Cisco Controller) > ap-type capwap
The AP will reboot one more time, then it will be in CAPWAP mode.
***Please rate all useful posts***
Jagan
