Converting AP4800 from CAPWAP to ME
benjmoor
Alright community - SAVE ME!  I've been looking through all of the documentation and I'm stumped.  How do I convert a CAPWAP 4800 to mobility express?  I've looked through this: https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/release_notes/b_ME_RN_810.html#me-supp-ap
and it says it is supported and I've downloaded the correct tar file and issued:
ap-type mobility-express tftp://10.72.222.55/AIR-AP4800-K9-ME-8-10-105-0.tar
I get:
Starting the ME image download...
It may take a few minutes to finish download.
If it is longer, please abort command, check network connection and try again
curl: (71) Error
transfer command failed
Image transfer failed. Please try again
I am sure that the TFTP process is correct because I put another AP on the same subnet and downloaded another image from the same TFTP server without an issue.  I'm looking at this:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/user_guide/b_ME_User_Guide_810/about_mob_exp.html
and it appears that the 4800 is not supported as mobility express?  So which is it?
Haydn Andrews
From the 4800 data sheet it says it can be a ME controller:
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-4800-access-point/nb-09-air-4800-acces-ds-cte.html
Your commands look correct.
Can you try using ftp instead of TFTP - have found sometimes TFTP struggles with large transfers
Do a show version and see if it says
AP Image type : MOBILITY EXPRESS IMAGE
AP Configuration : MOBILITY EXPRESS CAPABLE
Then its already converted
*****Help out other by using the rating system and marking answered questions as "Answered"*****
5 Replies 5
Leo Laohoo
What is the current firmware of the AP?
sho ver
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
Cisco AP Software, (ap3g3), C4800, RELEASE SOFTWARE
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu May 24 12:50:23 PDT 2018
ROM: Bootstrap program is U-Boot boot loader
BOOTLDR: U-Boot boot loader Version 2013.01-gacaad15 (Aug 18 2019 - 20:12:19)
AP10B3.D6D2.434E uptime is 0 days, 0 hours, 49 minutes
Last reload time : Wed Nov 6 23:43:28 UTC 2019
Last reload reason : reload command
cisco AIR-AP4800-B-K9 ARMv7 Processor rev 1 (v7l) with 1028396/613476K bytes of memory.
Processor board ID FCW2334PFT0
AP Running Image : 8.7.106.0
Primary Boot Image : 8.7.106.0
Backup Boot Image : 0.0.0.0
Primary Boot Image Hash:
Backup Boot Image Hash:
1 Multigigabit Ethernet interfaces
1 Gigabit Ethernet interfaces
3 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version : 2.4.23
Base ethernet MAC Address : 10:B3:D6:D2:43:4E
Part Number : 73-018776-02
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC23327EYK
Top Assembly Part Number : 068-100732-01
Top Assembly Serial Number : FCW2334PFT0
Top Revision Number : B0
Product/Model Number : AIR-AP4800-B-K9
Hi Benjmoor
If the AP is an ME AP you should see in the show version:
cisco AIR-AP1852E-UXK9 ARMv7 Processor rev 0 (v71) with 997184/525160K bytes of memory.
Processor board ID RFDP2BCR021
AP Running Image : 8.2.100.0
Primary Boot Image : 8.2.100.0
Backup Boot Image : 8.1.106.33
0 Gigabit Ethernet interfaces
0 802.11 Radios
Radio FW version . 1401b63d12113073a3C08aa67f0c039c0
NSS FW version : NSS.AK.1.0.c4-0Z026-E_cust C-1.24160
Given your not seeing it i'm guessing maybe the datasheet is not correct, or the version of that 4800 doesn't support it.
Since I see your a Cisco Employee might be easier for you to reach out to one of the Wireless SEs or TMEs and ask
Haydn Andrews
Definitely the FTP vs TFTP - little did I know that was even an option.  Thanks for the assistance!
