02-03-2015 10:55 AM - edited 07-05-2021 02:25 AM
Im looking to create a corporate wireless solution across my MPLS. I am using 5508s, flex connect and possibly 3650 switches.
i have implemented a guest environment and want to expand upon this.
Are there any practical guides on how to implement a coporate wifi?
i am particularly intested in how my users would tunnel back to their home sites to access resources.
Would I need to have a Ssid which is broadcast at all locations, which drops a user into a specific vlan on that site. I am authenticating via acs and radius. The user connects and can tunnel back to a home controller or something. I'd like a clearer understanding of how the components fit together and best practises
thanks
Solved! Go to Solution.
02-03-2015 12:35 PM
You can find all of Cisco's design guides here: http://www.cisco.com/go/srnd
02-03-2015 12:35 PM
