10-28-2018 09:00 AM - edited 07-05-2021 09:22 AM
Hello Guys
Pls find Attached Current WLC image on 2504
What is the latest image can Take
what is the steps to perform Upgrade
thanks all
Solved! Go to Solution.
10-29-2018 01:59 PM
Hi Ibrahim,
Since you are running 7.0.252.0 version that command may not applicable for your version.
For joining the AP temporarily to the controller, Remove NTP server from WLC and change the date of the controller. Hope this should help.
Below link for your reference.
once the APs joined to the controller. Please upgrade the controller to latest stable OS which should support all your access points. So that you wont face any certificate issue in future.
Sathiyanarayanan Ravindran.
10-28-2018 09:51 AM
- For both questions you need to go to cisco.com and -> Software downloads. Find the latest release for your platform, study the release notes and the installation & upgrade guides and or guidelines.
M.
10-28-2018 02:20 PM
10-29-2018 07:33 AM
Hello All
how to fix the below AP Complains , WLC still runs code 7.0
*Jan 1 01:02:56.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: <WLC IP> peer_port: 5246
*Jan 1 01:02:56.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Jan 1 01:02:56.418: %DTLS-5-ALERT: Received FATAL : Certificate unknown alert from <WLC IP>
*Jan 1 01:02:56.418: %CAPWAP-3-ERRORLOG: Bad certificate alert received from peer.
*Jan 1 01:02:56.418: %DTLS-5-PEER_DISCONNECT: Peer <WLC IP> has closed connection.
*Jan 1 01:02:56.418: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to <WLC IP>:5246
*Jan 1 01:02:56.418: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
10-29-2018 07:39 AM
- Upgrade the controller first, which is actually what you may need in the first place, the AP may have an old certificate. If the problem persists with the latest software version for the controller, then google on how to turn off certificate verification.
M.
10-29-2018 07:53 AM - edited 10-29-2018 07:53 AM
Not able to find the below command on WLC
For 7.0.252.0:
(WLC)>config ap lifetime-check {mic|ssc} enable
10-29-2018 08:24 AM
Which model AP is not joining to the controller?
Remove the NTP and then Change the year of WLC as 2017 or 2016 Under commands —> set time.
1131 model devices has this kind of issue..post reboot they won’t join to the controller due to certificate expire..
10-29-2018 11:13 AM - edited 10-29-2018 11:15 AM
This is the model
AIR-CAP3502I-A-K9
we have to know how Disable certificate check between AP and WLC
Also why the AP boots as below , as recovery image
Cisco IOS Software, C3500 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 30-Apr-12 13:33 by prod_rel_team
Loading "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx"...###############################################
thanks
10-29-2018 01:59 PM
Hi Ibrahim,
10-30-2018 06:20 AM
thanks bro
it Does work after change the clock on the WLC
10-30-2018 06:56 AM
Great!!
But it’s not a permanent solution. Upgrade your WLC as per the Cisco suggestion on the Field notice.
10-28-2018 03:55 PM
As per Cisco, Currently 8.0.152.0, 8.3.143.0 and 8.5.135.0 will be recommended images. You can upgrade to any of the above as per your Access Point model. Below links are for your reference.
Cisco Recommended Image for 2504
Consider below points before upgrading 2504 WLC
