Highlighted
Beginner
Data not showing in the security risk interferers Report in Cisco Prime Infrastructure after the Upgrade of WLC
Issue: After the upgrade of the WLC to 8.10.112.0 version, the report is not showing any data in the Cisco Prime infrastructure Under Report Launch Pad -> Clean Air -> Security Risk Interferers.
Analysis done:
-- Installed the latest device pack and the maintenance release in the Prime.
-- Removed and re-added the WLC in the prime.
-- Restarted the services. The WLC whenever downgraded to earlier version 8.3, the report will show.
WLC model: AIR-CT5520-K9
Version running: 8.10.112.0
Prime Model: PI-UCS-APL-K9
Version Running: 3.7 with latest patches and device packs
Is that feature doesn't support in the 8.8 and later versions of WLC ? Is cause whenever it is downgraded to lower version, the report will show. Is there any bug related to that ?
1 REPLY 1
Highlighted
VIP Engager
Re: Data not showing in the security risk interferers Report in Cisco Prime Infrastructure after the Upgrade of WLC
Content for Community-Ad
Cisco COVID-19 Survey
