ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Advisor
default ap's
   We are decommisioning a big site and we are looking at having to default the configs on about 40-50 ap's.  Other than manually logging into each ap via the controllers and defaulting them is there an easy way  to default a bunch of them at once  via either the controller or we have WCS at our disposal.  So far have not found a way in WCS to do this , you default controllers easy enough but haven't found a way via WCS to do mass ap's though I could be missing something obvious.
Everyone's tags (1)
8 REPLIES 8
Highlighted
Hall of Fame Master
Re: default ap's
WCS doesn't have that feature.  Or you can create a simple script and use the CLI:
clear ap config
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Highlighted
default ap's
If you console into the ap and delete private config
If you log into the controller you can delete the ap config by selecting the ap and hitting the clear all config button on the right
I suspect you can do a WCS template for this as well, dont have WCS in front of me to check
Hope this helps
__________________________________________________________________________________________
Highlighted
Re: default ap's
Just double checked... no love on WCS ...
Highlighted
Hall of Fame Master
Re: default ap's
That would be bad in case you had a disgruntled employee
Scott
-Scott
Highlighted
Re: default ap's
Disgruntled employees, huh who has any of those !  Oh, you must mean Leo or Steve ..
LOL
Highlighted
Re: default ap's
pull the names of the AP either out of WCS or the WLC.  then create a text file
clear ap config < AP Name>
rinse, repeast for all the AP, then paste into the CLI of the WLC.  Or use the WLC to push this as a CLI template.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Highlighted
Advisor
Re: default ap's
  Yeah that might work ,  in WCS I can make a CLI template with all the entries and just run it against the controller ,
clear ap config  1
clear ap config 2
etc....
Thanks...
Highlighted
Hall of Fame Master
Re: default ap's
Yup those two!
-Scott
Content for Community-Ad
