05-16-2019 08:18 PM - edited 07-05-2021 10:25 AM
Hello folks, I'm wondering let's say I have a switch that I can access remotely only.
The switch is IP address is configure below:
switch1#
! int vlan 6 ip address 192.168.6.5 255.255.255.0 ! !
int vlan 120 ip address 192.168.120.5 255.255.255.0 ! ip route 0.0.0.0 0.0.0.0 192.168.6.1 !
So when I want to access the switch I just use the mgmt IP address 192.168.120.5 to do so. So now let's say VLAN 6 will go away and I have to delete the int vlan 6 from the switch and only use vlan 120 to access the switch. I also must delete that static route since that gateway of 192.168.6.1 will not exist anymore. How would I do this without losing permanent access to my switch?
I know that the ip route command puts me under the default route for a gateway that does not exist anymore and I must point the default route now to 192.168.120.1.
05-16-2019 08:42 PM
Hi @Amafsha1 ,
That's right.
Without more details of your network.
I suggest you see the effect of this and be aware of possible complications.
05-16-2019 10:40 PM - edited 05-16-2019 10:41 PM
so the default gateway SVI resides at the core router which is trunked to this switch that I'm changing the IP for.
