08-20-2012 11:17 PM - edited 07-03-2021 10:33 PM
Hi everyone,
How does the WLC handle multicast traffic (HSRP,STP etc) originated in the WLAN subnets?
Do we need to specify ACLs on filter them or are they blocked by default?
If ACLs required, is it best to apply on SVIs or on the WLC itself ?
please advice.
Silva
Solved! Go to Solution.
08-21-2012 03:33 AM
Any multicast and broadcast traffic is blocked at the wlc by default unless you are allowing multicast traffic or if you you are forwarding broadcast traffic. The traffic you mentioned are blocked by the wlc.
08-21-2012 05:55 AM
The WLC by default has multicast traffic option disable, so if you need to work with multicast you will need to enable multicast on the WLC if the access points are on the same subnet as the WLC, if the access points are on a different subnet then the WLC you will need to also enable layer 3 multicast on your switches or routers.
08-21-2012 03:33 AM
08-21-2012 05:55 AM
08-22-2012 03:50 PM
Hi Scott and fbarboza,
Thanks for the calrification.
regards
Silva
