Deployment a Guest WLAN
Hello guys, thanks for everyone I have another questions I'm going to deploy a new guest WLAN I'm working with the addressing and one questions come to me.. I have this central site and I have some remote offices this new WLAN will be available in different sites so... what is the best option... have just one segment for this WLAN or have different addressing for site? and the most important part... is this posible? I mean one WLAN can has differente Addressing between sites?
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Scott Fella
Here is a doc that can help you understand FlexConnect.
https://supportforums.cisco.com/docs/DOC-24082
-Scott
16 Replies 16
Scott Fella
The main thing to ask first is if you want all the guest traffic to come back to the WLC at HQ. If you are okay and have the bandwidth for this, then you just centrally switch the guest SSID from the remote locations and all guest will be placed in whatever interface you create for guest at HQ. so you have options, you can locally switch traffic at the remote site, but then you need to ACL the guest subnet so they can't access your internal, except for maybe dhcp or DNS.
The AP's at HQ will be in local mode and the remote site should be in FlexConnect mode.
-Scott
Sorry Scott.
Whay means HQ ? if I don't have enought bandwith I need to create a ACL? I really need it?
HQ meaning heawd quarters:)  What is your link between sites?
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Well I have different links
one for 6MB, 4MB, 512K and 256 K
Do you have internet at each location or does everything come back?
Scott
-Scott
some sites have their own internet and some of them comeback
SO you have to decide if the guest traffic will tunnel back to the WLC or not.  The sites that have their own Internet, you would have to create a new subnet/vlan and create an ACL to block the guest user from accessing your internal network.  Even if you have the guest tunnel back to the WLC, you need to have an ACL block guest traffic to your internal.
Scott
-Scott
ACL? I never used before
It's mandatory? or it's Diffcitult to configure aCL?
ACLs on a WLC are "different" ...
Check this link
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00807ce372.shtml
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Scott Fella
-Scott
So it's posible that one SSID have different adressing? I mean one for my central site, one for my remote site, one for my remote site B etc?
So the thing is, will you be tunneling the traffic for the guest?  If so, then you will only have one subnet you can put all the guest users if you have one SSID.
Scott
-Scott
Ok. One question I'm testing this in a lab, right now I'm simulated be on my remote site and I conneted to my SSID FERROMEX, this SSID is centrall switched I have one interface in my WLC on my Central site, the vlan is on my cental site too, and I'm working just fine. I don't have anny ACL's I really need this ACL?
Sorry if my queston is so abviuos, but the is new for me
What do you mean by this
The SSID is centrally switched so the only interface that is required is on the WLC. That vlan has to reside in the central site and not needed in the remote site. If your placing internal users and guest users in the same subnet, then you can't use ACL's as the guest will be able to access your internal network also.
-Scott
