229
Beginner
Dhcp delay when moving to a different site
We have 2 sites with a controller in each one with the same configuration. Each site has the same SSID but different DHCP pool range. Each time a user moves from one site to the other and connects, it keeps the same IP address from the previous site. Is this because of L2 Inter roaming? If so, how do I get it to recognize its a different site and ask for a new IP lease?
11 REPLIES 11
Highlighted
VIP Advisor
Re: Dhcp delay when moving to a different site
As per my understanding, if you do not like roaming, you should treat each site as seperate.
BB
*** Rate All Helpful Responses ***
Beginner
They are separate. They just have the same SSID.
Hi @MiguelCarillo
This two site are geographically separate? You need to check if networks segments are different in both sites, under Interfaces section check the Dynamic interfaces configuration, especially DHCP server. Another question... are you using a Mobility Domain?
Beginner
They are geographically separate. Each network is standalone but we do have a vpn connecting between them.
We are not using a mobility domain. We are using mobility groups but each site is different.
Ok.
Miguel, are you using Dynamic interfaces for your SSIDs?
Under DHCP server in each dynamic interface check that you are using a different DHCP server.
Beginner
Yes we are using Dyanmic interfaces. Each controller is using the local DHCP server.
Can u share the output of "show running-config no-ap" of both WLC?
Beginner
That command does not apply. We are using 3650s
VIP Advocate
Clients keep their IP addresses if the lease time is still valid and the SSID is the same. Unless mobility or L3 roaming is correctly configured, they will have an issue.
One way to solve this, is to lower the DHCP lease timeout to a time smaller than what is required to move from building one to two. The clients still have a short outage while waking from sleep, because they try to renew their old/wrong IP address, but then should get assigned a new one from the correct range.
Beginner
What do you mean by "Unless mobility or L3 roaming is correctly configured"
VIP Advocate
Content for Community-Ad
August's Community Spotlight Awards
