01-11-2009 06:43 AM - edited 07-03-2021 04:58 PM
I configured dhcp server on the Aironet 1242AG. There are two SSID's on the Aironet how can I bind this dhcp server to one of the SSID's so all the clients authenticating to this SSID will get their IP from the DHCP server that I configured on the Aironet?
01-12-2009 08:33 AM
so long as the DHCP scope matches the network you want the client to get DHCP from,it should work. When the client attempts to get DHCP it will do a subnet broadcast looking for the DHCP server, and the AP should respond.
01-12-2009 09:15 AM
That is true but there are two SSID's and I want one SSID to be able to use one DHCP server and second SSID to use the DHCP server that is on the AP.
12-11-2010 06:41 AM
Did you ever find a solution?
I'm looking for the same setup but have not found it.
12-11-2010 07:18 AM
it will be great if you could start a new discussion for this issue..
Surendra
