11-28-2012 07:32 AM - edited 07-03-2021 11:07 PM
What is the process for creating DHCP option 43 in Microsoft Windows Server without using any Cisco AP vendor codes so that several different models of AP in the same VLAN can get the IP addresses of the controllers ?
Solved! Go to Solution.
11-28-2012 07:37 AM
Fairly simple, you just define option 43, you don't go in and do the VCI/Option 60.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
11-28-2012 07:37 AM
HTH,
Steve
11-28-2012 08:04 AM
Yeah what Steve said:)
11-28-2012 08:28 AM
Will it let you specify the IP addresses of several controllers when you do this it's generic for any AP then ?
11-28-2012 09:08 AM
There's no need to specifiy more than one WLC. When the WLC replies to the discover request, it sends teh AP all the WLC that are in the mobility group, max capacity, and excess availablity.
HTH,
Steve
11-28-2012 10:28 AM
What if you wanted to specify more for failover reasons in case the one is offline ? Is there a way to specify four ?
11-28-2012 10:33 AM
Not to my knowledge.
But again, once the AP has joined one WLC, it knows about all the others in the mobility group. So if one fails, it will try to join another. If you configure the primary/secondary/tertiary it will try them in that order.
HTH,
Steve
11-28-2012 10:52 AM
Thanks for all your help today.
Rich
12-04-2012 09:42 PM
Steve -- Great info. VIP Endorsed ..
Always enjoy learning something new I didnt know before.
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
