Philip,
In a Guest Anchor Setup the DHCP proxy is handled on the anchor controller as this is where the client will be dropped into its specific vlan.
Then depending on your DHCP setup will determine the Proxy method chosen.
What is your DHCP solution at the Anchor Controller?
Roger
