Diferent DHCP servers with the same ssid
sonel.claudiu
I have 8 APs AIR-AP3702I and a controller WLC 2504. I want to have the same SSID, but I want that 4 of them to use 10.0.0.0/24 ip pool, and other 4 to use 10.0.2.0/24 pool.
Claudiu
2 Accepted Solutions
sobhardw
Please refer to the below link :
https://supportforums.cisco.com/document/74486/ap-group-vlan-logic-wireless-lan-controllers-wlc-configuration-example
Here is the step by step GUI configuration guide of the AP group VLans with images.
https://www.cisco.com/public/technotes/smbsa/en/us/wireless/config_AP_Grp_VLANs_WLANs.pdf
for reference please look the below steps
Steps to configure via GUI
  1. Go to the controller GUI and choose WLANs > AP Groups VLANs.
  2. Check AP Group VLANs Feature Enable and then click Apply in order to enable the AP Group VLANs feature.
  3. Enter the AP Group Name and Description and then click Create New AP-Group in order to create a new AP group.
  4. For the new AP group , click on Detail. Select the appropriate SSID from the WLAN SSID pull-down menu and the interface with which you wish to map this AP group.  [  The final task is to assign the LAPs to the appropriate AP groups  ]
  5. Go to the controller GUI and choose Wireless > Access Points > All APs.
  6. Click on the Detail link for an LAP in order to assign an LAP to an AP group.
  7. Set AP Group Name to the name of the appropriate AP group from the AP Group name
Stephen Rodriguez
You will want to look into the AP Groups feature.
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/71477-ap-group-vlans-wlc.html
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
sobhardw
gohussai
Level 4
Level 4
You need "AP Group VLANs feature" in your 2504 Controller.
Check the following link for proper configuration step by step.
