Cisco Community Designated VIP Class of 2020
25838
Beginner
disable 2.4 Ghz radio on lightweight AP
Hi All,
Can someone tell me how I can disable the 2.4 Ghz radio on a single lightweight AP?
Thanks in advance!
1 ACCEPTED SOLUTION
Hall of Fame Master
If you want to do this from the GUI, clcik on the Wireless | Access Points | Radios | all the way on the right is a blue triangle, click that next to the AP you want to disable the band and click configure.  There you will disable the radio.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
18 REPLIES 18
Hall of Fame Master
From the CLI you can issue a:
config 802.11a disable
config 802.11b disable
Scott
-Scott
Hall of Fame Master
Scott
-Scott
Beginner
Hello, I need to disable 2
I need to disable 2,4GHz and enable 5Ghz radio only at one LAP.
Hall of Fame Community Legend
Scott's method to disable a
Scott's method to disable a radio for a specific AP.
If you want CLI, the command is "config 802.11b  disable AP_name ".
Beginner
Ok disabled, but when trying
Ok disabled, but when trying to enable a or n:
AP does not support the specified radio type.
The followings are supported radio types of the AP:
 802.11b
The command to enable 802.11b
The command to enable 802.11b on a specific AP is "config 802.11b enable AP_name".
Highlighted
Beginner
I'm sorry leo, you are not
I'm sorry leo, you are not following me...
I need to disable 1 out of 11 APs the 2,4GHz (b/g/n) because when trying to airplay to an apple tv I have many issues with bluetooth mouses (same frequency). So I need only 5GHz at this AP
TY
I see.  Can you post the
I see.  Can you post the complete output to the command "show ap config general AP_NAME".
I have a strange feeling the AP you want to enable 802.11a/n is only single-radio or the wrong Regulatory Domain.  This is why you are getting the error message when you attempt to enable 802.11a/n
Beginner
(Cisco Controller) >show ap
(Cisco Controller) >show ap config general APBlissMeetRoom
Cisco AP Identifier.............................. 3
Cisco AP Name.................................... APBlissMeetRoom
Country code..................................... PT  - Portugal
Regulatory Domain allowed by Country............. 802.11bg:-E     802.11a:-E
AP Country code.................................. PT  - Portugal
AP Regulatory Domain............................. 802.11bg:-E
Switch Port Number .............................. 1
MAC Address...................................... 00:06:f6:d2:65:57
IP Address Configuration......................... Static IP assigned
IP Address....................................... 192.168.2.210
IP NetMask....................................... 255.255.0.0
Gateway IP Addr.................................. 192.168.2.252
Domain...........................................
Name Server......................................
NAT External IP Address.......................... None
CAPWAP Path MTU.................................. 1485
Telnet State..................................... Disabled
Ssh State........................................ Disabled
Cisco AP Location................................ default location
Cisco AP Group Name.............................. default-group
Primary Cisco Switch Name........................
--More-- or (q)uit
Primary Cisco Switch IP Address.................. Not Configured
Secondary Cisco Switch Name......................
Secondary Cisco Switch IP Address................ Not Configured
Tertiary Cisco Switch Name.......................
Tertiary Cisco Switch IP Address................. Not Configured
Administrative State ............................ ADMIN_ENABLED
Operation State ................................. REGISTERED
Mirroring Mode .................................. Disabled
AP Mode ......................................... Local
Public Safety ................................... Disabled
AP SubMode ...................................... Not Configured
Remote AP Debug ................................. Disabled
Logging trap severity level ..................... informational
Logging syslog facility ......................... kern
S/W  Version .................................... 7.2.115.2
Boot  Version ................................... 12.4.23.6
Mini IOS Version ................................ 7.4.1.37
Stats Reporting Period .......................... 180
LED State........................................ Enabled
PoE Pre-Standard Switch.......................... Disabled
PoE Power Injector MAC Addr...................... Disabled
Power Type/Mode.................................. Power injector / Normal mode
Number Of Slots.................................. 1
AP Model......................................... AIR-LAP1141N-E-K9
AP Image......................................... C1140-K9W8-M
IOS Version...................................... 12.4(25e)JA2$
Reset Button..................................... Enabled
AP Serial Number................................. FCZ1707Z0J1
AP Certificate Type.............................. Manufacture Installed
AP User Mode..................................... AUTOMATIC
AP User Name..................................... Not Configured
AP Dot1x User Mode............................... Not Configured
AP Dot1x User Name............................... Not Configured
Cisco AP system logging host..................... 255.255.255.255
AP Up Time....................................... 53 days, 03 h 52 m 36 s
AP LWAPP Up Time................................. 3 days, 12 h 00 m 28 s
Join Date and Time............................... Fri Apr  4 21:57:05 2014
Join Taken Time.................................. 0 days, 00 h 02 m 00 s
Ethernet Port Duplex............................. Auto
Ethernet Port Speed.............................. Auto
AP Link Latency.................................. Disabled
Rogue Detection.................................. Enabled
AP TCP MSS Adjust................................ Disabled
Venue Name....................................... Not configured
Venue Group...................................... Unspecified
Venue Type....................................... Unspecified
Language Code.................................... Not configured
Ok.  Just as I have suspected.  The AP in question only has one (1) radio and it's only 802.11b.   You will never be able to enable 802.11a.
Beginner
Ok. So I have to forget the
Ok. So I have to forget the config part of the LAP. we have many issues with airplay to apple tv and some forums says that is Bluetooth (mouse) and wireless problems. Any way to round this?
Hall of Fame Master
It's not the Bluetooth mouse.
It's not the Bluetooth mouse.... I run that and a couple Apple TV's at home and I have also implemented schools with Apple TV's in each room....
-Scott
Beginner
But is the wireless? Is the
But is the wireless? Is the Apple TV? Any clues/tips?
Hall of Fame Master
Put the Apple TV's and the
Put the Apple TV's and the devices that use the APple TV's on the same subnet and see if that helps.  I don't know how you have your wireless setup, so its hard to tell you what to do.
-Scott
Content for Community-Ad
August's Community Spotlight Awards
