Community Helping Community
25165
Beginner
Hi Scott, we have a /16 as
Hi Scott, we have a /16 as you see by the subnet mask -> 255.255.0.0
They are all at the same.
Hall of Fame Master
Sure.... It's config 802.11b
Sure.... It's config 802.11b disable
-Scott
Beginner
Quick question.  Does
Quick question.  Does performing this actually stop the radio from transmitting?  I am trying to clear some of the 2.4ghz congestion for a specific non-wifi application that is having trouble due to channel interference.
I have disabled a lot of radios, but when I go to a radio that I left active I can see all of the disabled radios in the monitor...
It appears to not be broadcasting the SSID's but it is still active as a transmitter.  Will this still cause as much interference as before...
Alex.
Hall of Fame Master
That is what I have done was
That is what I have done was disable the radio on the AP.  This does stop transmitting for that radio.
-Scott
-Scott
Content for Community-Ad
August's Community Spotlight Awards
