03-01-2019 06:26 AM - edited 07-05-2021 09:57 AM
We are in a school district that often hosts robotics competition. Robotics equipment require us to turn off all radios so there are no interference with their signals.
So far we have been shutting down the ports connected to the APs or simply unplugging the AP from the ports.
---I have found where Wireless- 802.11b/g/n - network where you can enable all status.- will not work. I only need to do this for one ap group at one school.
--- have also found under Wireless - All APs where you can disable status on one AP at a time. - too slow.
--->Is there a way to disable all radios in a single AP group?
Thanks for your time.
Solved! Go to Solution.
03-01-2019 04:36 PM
The "fastest" way is to create an RF Profile where all the Data Rates are disabled and assign to the AP Group, however, when an RF Profile is changed in an AP Group the APs reboot.
Another method is to remove all the SSID from the AP Group so all APs in that particular AP Group is not broadcasting any SSID.
03-01-2019 04:36 PM
03-05-2019 03:57 AM
03-13-2019 08:10 AM
I created a test Group and removed all SSID from the AP group. this is working for us. Thanks for you help.
03-05-2019 01:44 AM - edited 03-06-2019 05:05 AM
I've created a WLAN group called "Disabled", with no WLANs active. Then, under the AP Group you can select the WLAN Group that radios go into - just select the Disabled WLAN Group you created.
