08-07-2018 12:09 PM - edited 07-05-2021 08:57 AM
Hi guys.
I have setup cisco 877w connected in non root bridge mode to other non cisco wireless N router (I don't have administrative access to it). I'd like to disable B mode at 877w router and increase link statility
Current configuration:
interface Dot11Radio0
description -= outside WBR 2 management AP =-
ip address dhcp
ip access-group di_in in
ip nat outside
ip inspect dial out
ip virtual-reassembly in
ip tcp adjust-mss 1360
encryption mode ciphers aes-ccm
ssid PS-mgmt
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
packet retries 24 drop-packet
station-role non-root
antenna gain 0
crypto ipsec df-bit clear
Could you suggest if bellow is right code to disable B mode channel?
speed basic-12.0 18.0 24.0 36.0 48.0 54.0
Also is it good idea to enable short preamble (by enabling "short-slot-time")? maybe somebody can suggest "best practices" methods to increase link stability? Distance between management AP and 877w router no more 10-15 meters. Open space. signal strength 59-67 dbm. c877w and management AP have installed two omni direction (unfortunately) 8dbm antennas:
c877w association info:
gate-ctr745(config-if)#do sh dot11 ass all
Address : 6e12.5161.a46c Name : NONE
IP Address : 0.0.0.0 Interface : Dot11Radio0
Device : unknown Software Version : NONE
CCX Version : NONE
State : Assoc Parent : Our Parent
SSID : PS Campers VLAN : 0
Hops to Infra : -1 Association Id : 297
Tunnel Address : 0.0.0.0
Key Mgmt type : WPAv2 PS Encryption : AES-CCMP
Current Rate : 54.0 Capability : WMM ShortHdr ShortSlot
Supported Rates : 1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
Signal Strength : -61 dBm Connected for : 82254 seconds
Signal Quality : N/A Activity Timeout : 15 seconds
Power-save : Off Last Activity : 0 seconds ago
Packets Input : 246103 Packets Output : 306290
Bytes Input : 97304626 Bytes Output : 73647712
Duplicates Rcvd : 9773 Data Retries : 81648
Decrypt Failed : 0 RTS Retries : 0
MIC Failed : 0 MIC Missing : 0
Packets Redirected: 0 Redirect Filtered: 0
data retries counters increasing and once in ~1 hour I link drop down with "Too many retries" error notification:
068353: Aug 7 14:02:06: %DOT11-4-UPLINK_DOWN: Interface Dot11Radio0, parent lost: Too many retries
Thank you.
08-07-2018 01:22 PM
1,2,5,5 & 11 Mbps are 802.11b rates which use DSSS modulation. 6 & 9 Mpbs is use OFDM & part of 802.11g rates.
In your case, it is ok to disable 6 & 9 Mbps as well & go with what you came up with.
Ideally you need to set it at Root AP level to avoid any mismatch of basic rates.
does it got dual band radio/antenna ? If so, I would use 5GHz for a stability & higher performance. I would not suggest to enable short preamble
Rasika
*** Pls rate all useful responses ***
08-08-2018 07:40 AM
I see. Thank you Rasika.
