03-09-2019 04:11 AM - edited 07-05-2021 10:01 AM
Hello
i have 26 access point 1815i and controller 3504 .
But i would to knwo how many distance between these access point that allow no problem and a good connectivity
thers access point parts are placed inside local and other place on the roof !!
Solved! Go to Solution.
03-09-2019 04:27 AM
cisco what distance recommended betwwen acces point indoor in local and in roof !!
please i need a help and answer for team wireless
thanks
03-09-2019 05:00 AM
03-09-2019 01:53 PM
APs are inside ceiling spaces?
Then "all bets are off". There are more ways to kill WiFi propagation when APs are inside the ceiling spaces. It's never a recommended "best practice".
If the customer wants to protect the APs from theft, then mount the AP high and/or use a zip tie.
03-09-2019 04:22 PM
As Leo has said was a wireless survey done. If not highly recommend that one be done, this is the first step in ensuring that you get good WIFI. I also recommend that a validation survey be done when the wireless has been commissioned.
It is normally NOT recommended to place APs in the ceiling as this adds an attenuation layer straight away. There are many other ways to "hide" the APs using skins and randoms.
That being said normally you do not want the APs to be closer than 8-12m when using omni antennas, but this is dictated by the environment and how much RF attenuators are between the APs.
03-09-2019 04:27 AM
thanks
03-09-2019 04:22 PM
03-09-2019 05:00 AM
03-09-2019 06:22 AM
as suggested by @Leo Laohoo
This is require more site survey, there is no thumb rule the wireless work as expected
each site have different requirement
suggest to contact local partner to conduct site survey, so you can mount the WAP in better place to give better survey.
always suggest to re-do some site survey since Location of equiment changes. and you see more interference with other device on the floor or site.
03-09-2019 07:15 AM
Please , can you give me example Site survey cisco to download and that can used for my projet
thanks in advance
03-09-2019 07:51 AM
03-09-2019 01:53 PM
