07-26-2012 02:01 PM - edited 07-03-2021 10:27 PM
Can anyone tell me what is the purpose of DNS hostname under the virtual interface? Is it a required parameter for web-authentication / how does it affect the web authentication?
Thanks in advance
Jino
Solved! Go to Solution.
07-26-2012 02:05 PM
The host name under the virtual interface is for if/when you put a third party certificate in the WLC. When you register for the cert, the name you put under the virtual interface is what you use for the cert.
Steve
07-26-2012 02:05 PM
Steve
07-26-2012 02:07 PM
It's if you installed a 3rd party certificate. You enter the FQDN and you add a DNA record to resolve the FQDN to the VIP.
07-26-2012 02:17 PM
Many thanks for the swift response.
