Highlighted
Beginner
Does option 43 matter ? WLC5508 ver 7.2 using internal DHCP server
I am using a WLC 5508 and its internal DHCP server. I cant find anywhere I can setup option 43. However, the access points are connected in just fine. Do I need to worry about setting up a seperate DHCP server to get option 43 setup properly ?
Thank you.
1 ACCEPTED SOLUTION
Highlighted
If you want to have AP on a different subnet from the WLC, then yes you would want to configure another server and option 43.
If you're fine wtih your current setup, then no.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
7 REPLIES 7
Highlighted
Hall of Fame Master
Re: Does option 43 matter ? WLC5508 ver 7.2 using internal DHCP
Option 43 is to help the APs join the wlc. Your APs already are joined and this isnt used by clients.
Scott Fella
Sent from my iPhone
-Scott
Highlighted
Beginner
Sorry I didnt make my question clear.
When I connect a CAPWAPP Access Point to the network, it receives IP address from the WLC 5508 DHCP service just fine. It shows up in the access points list and users can connect to it no problem.
Highlighted
HTH,
Steve
Highlighted
Beginner
Stephen,
I want to rate your answer is a correct answer.
Do you any chance have a doc from Cisco saying this?
Highlighted
http://www.cisco.com/image/gif/paws/97066/dhcp-option-43.pdf
It's in the introduction.
HTH,
Steve
Highlighted
Beginner
Option 43 to join specific Wireless LAN Controllers (WLCs) when the WLC is in a different subnet than the LAP.
Awesome! Thank you.
Highlighted
Hall of Fame Master
You don't new option 43. The internal dhcp doesn't allow you to create any options, just default dhcp requirements.
Scott Fella
Sent from my iPhone
-Scott
Content for Community-Ad
