Highlighted
Beginner
Does resetting system config of a 2504 WLC remove adder licenses?
I purchased a used Cisco WLC 2504 with a screenshot that says "10 Access Points Supported". I did a system reset on the unit because I didn't know the password. Now, after I login to the web UI, the summary page says "5 Access Points Supported".
Does resetting the system config cause all adder licenses to be removed? I think 5 APs come with the base license, and you can purchase additional adder licenses?
If I go into Advanced > Management > Software Activation > Licenses, I see the following licenses:
License: base, Type: permanent, Time (expires): No Expiry, Count: NA, Priority: Medium, Status: Active, Not in Use
License: base-ap-count, Type: permanent, Time (expires): No Expiry, Count: 5, Priority: Medium, Status: Active, In Use
License: base-ap-count, Type: evaulation, Time (expires): 12 weeks, 6 days, Count: 75, Priority: None, Status: Inactive
Everyone's tags (4)
2 REPLIES 2
Highlighted
VIP Mentor
Re: Does resetting system config of a 2504 WLC remove adder licenses?
Normally not if you have saved the conifg!
did you you save the config after installing license?
did you reboot after installing adder license?
Highlighted
Beginner
This was a used unit that I purchased secondhand, so I never installed any licenses. The seller showed me a screenshot that said 10 access points were supported. After I received the unit, the access point showed that only 5 access points were supported.
Content for Community-Ad
