03-05-2013 10:04 PM - edited 07-03-2021 11:40 PM
Good Day. I would like to ask if the Cisco Aironet 1550 Series needs a controller to run. Notice that the SKU's are in this fomat AIR-CAP1552E-A-K9 AIR-CAP1552EU-A-K9. I have noticed that on the stand-alone AP's it has they keyword 'SAP' on its SKU while the controller based has 'CAP'. If the
Cisco Aironet 1550 Series needs a controller which controller should it be paired? (e.g. AIR-CT2500)
Solved! Go to Solution.
03-05-2013 10:29 PM
It can run autonomous image:
1550 is supported on:
2500, 7500, 5508, WISM2 , ...etc
check the release notes of the controller code you have and you should be able to identify what is supported and what is not supported.
please make sure to rate correct answers
03-05-2013 11:05 PM
Yeah you need IOS release to run in standalone ( autonomous mode ).
second question: not necessary
03-05-2013 10:29 PM
03-05-2013 10:39 PM
Hi Maldehne,
When we say it can run autonomous image, does it mean it has to be loaded with an IOS Release that supports autonomous mode in order to run stand-alone? If yes, then I would say that by default this AP needs a controller to run?
03-05-2013 11:05 PM
03-05-2013 11:46 PM
Hi Maldehne,
Thanks for your help.
