143
Beginner
Error in setting community status during configuration in PI.
Hello all,
I've monitored using PI my APs...
During monitoring, I clicked Apply at SNMP tap.
But upper log came out..
In this case, what should I do ?..
That issue came out before 1 week...
SK.
1 ACCEPTED SOLUTION
Hall of Fame Master
Okay.. well I would try just
Okay.. well I would try just setting one and see if the error goes away. If so, then at least you know you are hitting a bug:)
-Scott
-Scott
7 REPLIES 7
Hall of Fame Master
If your not using v3 then
If your not using v3 then disable that and just try v2. If your using v3 then disable v2.  I would setup v2 first.
-Scott
-Scott
Highlighted
Beginner
Thank you Scott.
Thank you Scott.
What do you mean V2 and V3..?
SK
Hall of Fame Master
I'm looking at the screen
I'm looking at the screen shot you attached. It's complaining about snmp community strings.
-Scott
-Scott
Beginner
Ah!
Ah!
My superior staff want to use V2 and V3 both...!
Hall of Fame Master
-Scott
-Scott
VIP Mentor
Are these WLC managed APs or
Are these WLC managed APs or standalone APs ?
Rasika
Beginner
AP image type : MOBILITY
AP image type : MOBILITY EXPRESS IMAGE..
Actually I don't know whether standalone or not .
How can I verify that?
SK
Content for Community-Ad
August's Community Spotlight Awards
