Error in setting community status during configuration in PI.
Soon Kwan Kwon
Hello all,
I've monitored using PI my APs...
During monitoring, I clicked Apply at SNMP tap.
But upper log came out..
In this case, what should I do ?..
That issue came out before 1 week...
SK.
Okay.. well I would try just setting one and see if the error goes away. If so, then at least you know you are hitting a bug:)
-Scott
-Scott
7 Replies 7
Scott Fella
If your not using v3 then disable that and just try v2. If your using v3 then disable v2.  I would setup v2 first.
-Scott
-Scott
Thank you Scott.
What do you mean V2 and V3..?
SK
I'm looking at the screen shot you attached. It's complaining about snmp community strings.
-Scott
-Scott
Ah!
My superior staff want to use V2 and V3 both...!
-Scott
-Scott
Are these WLC managed APs or standalone APs ?
Rasika
AP image type : MOBILITY EXPRESS IMAGE..
Actually I don't know whether standalone or not .
How can I verify that?
SK
