1059
Beginner
Error Messages : %OSAPI-4-MSGQ_SEND_FAILED , %OSAPI-3-MSGQ_RUNNING_HIGH , %LOG-4-Q_IN
Hi Friends,
Need your help in understanding the reason for below error messages -
(WLC01) >grep include MFP "show msglog"
Press any key to continue..
*dtlArpTask: Apr 23 09:28:56.206: %LOG-4-Q_IND: osapi_msgq.c:903 Failed to send a message to the message queue object: MFP-Q. enqueue failed.[...It occurred 48 times.!]
             *spamApTask3: Apr 23 09:28:55.558: %OSAPI-4-MSGQ_SEND_FAILED: osapi_msgq.c:903 Failed to send a message to the message queue object: MFP-Q. enqueue failed.
*spamApTask6: Apr 23 09:28:55.520: %OSAPI-3-MSGQ_RUNNING_HIGH: osapi_msgq.c:926 Message queue MFP-Q is nearing full. Capacity 256 Messages 244.
*apfMsConnTask_7: Apr 23 09:28:49.969: %LOG-4-Q_IND: osapi_msgq.c:903 Failed to send a message to the message queue object: MFP-Q. enqueue failed.[...It occurred 202 times.!]
                   *spamApTask3: Apr 23 09:28:48.344: %OSAPI-4-MSGQ_SEND_FAILED: osapi_msgq.c:903 Failed to send a message to the message queue object: MFP-Q. enqueue failed.
*spamApTask6: Apr 23 09:28:48.340: %OSAPI-3-MSGQ_RUNNING_HIGH: osapi_msgq.c:926 Message queue MFP-Q is nearing full. Capacity 256 Messages 244.
*spamApTask6: Apr 23 09:28:48.340: %LOG-4-Q_IND: osapi_msgq.c:903 Failed to send a message to the message queue object: MFP-Q. enqueue failed.[...It occurred 577 times.!]
               *spamApTask3: Apr 23 09:28:41.282: %OSAPI-4-MSGQ_SEND_FAILED: osapi_msgq.c:903 Failed to send a message to the message queue object: MFP-Q. enqueue failed.
*spamApTask2: Apr 23 09:28:41.281: %OSAPI-3-MSGQ_RUNNING_HIGH: osapi_msgq.c:926 Message queue MFP-Q is nearing full. Capacity 256 Messages 244.
*spamApTask2: Apr 23 09:28:41.281: %LOG-4-Q_IND: osapi_msgq.c:903 Failed to send a message to the message queue object: MFP-Q. enqueue failed.[...It occurred 685 times.!]
               *spamApTask7: Apr 23 09:28:34.273: %OSAPI-4-MSGQ_SEND_FAILED: osapi_msgq.c:903 Failed to send a message to the message queue object: MFP-Q. enqueue failed.
*spamApTask6: Apr 23 09:28:34.273: %OSAPI-3-MSGQ_RUNNING_HIGH: osapi_msgq.c:926 Message queue MFP-Q is nearing full. Capacity 256 Messages 244.
(WLC01) >grep include MFP "show queue-info"
Would you like to display more entries? (y/n) y
Q-Id Queue Name                    Allocated  MsgSize   InUse   MaxUsed Breached* Details
19   MFP-Q                                          256       29               0            256                         4         N
FOR MORE LOGS PLEASE FIND THE ATTACHEMENT.
Laukik N.
1 ACCEPTED SOLUTION
Highlighted
Re: Error Messages : %OSAPI-4-MSGQ_SEND_FAILED , %OSAPI-3-MSGQ_RUNNING_HIGH , %LOG-4-Q_IN
Hi Laukik,
This is a cosmetic bug and won't impact your service at all.
Please disable MFP as workaround.
Permanent fix you need to upgrade the wlc to 8.3.130.0 and above.
Vengat
3 REPLIES 3
Participant
Hi Vengatesa,
How can I change the sleep time to 1ms, using GUI ?
Laukik.
Highlighted
Hi Laukik,
Vengat
Content for Community-Ad
August's Community Spotlight Awards
