error schedule guest user
Radek Vesely
I have a 5500 WLC 7.0.220.0 and NCS 1.0.2.29. I trying create schedule guest user.
Error(s): You must correct the following error(s) before proceeding:
Error:Unknown Exception Occured. If the problem persists please send logs to the Tech Support.
normal guest user is working well done.
Do you know where it could be a mistake?
Amjad Abdullah
Try another browser (only supported browsers are IE and FF).
If supported browsers (both of them) show same problem you need to open a TAC case for further investigation because it seems your product has a problem. Exceptions mean something worng with the internal coding of the system. TAC only can help on this.
Amjad
Rating useful replies is more useful than saying "Thank you"
fbarboza
Level 4
Level 4
Correct, the supported browser to use to configure the WLC is IE since the GUI works with a lot of popups and most web browsers have pop up blockers enable.
Are you using a WCS or NCS server to configure the WLC?
I've tried most of the browsers all the time same problem. I use NCS.
I use NCS v.1.0.2.29
Hi , In this case the best option and path to take is to open a case with TAC requesting assistance with the NCS support team and let them know you are getting the following error message:Error(s): You must correct the following error(s) before proceeding: when trying to create a scheule guest user using the NCS.
Cisco Worldwide Contact link is below for further reference.
http://www.cisco.com/en/US/support/tsd_cisco_worldwide_contacts.html
