Highlighted
Error upgrading AIR-CT2504: "Failure while validating the signature!"
Hi All. This is is to ask if you had this issue in order to help me with your experience.
I was trying to upgrade CT2504 from 8.2.151.0 to 8.3.150.0 but when the copy is finished, either TFTP o SFTP, by CLI or GUI, fails and ends with this message: "Failure while validating the signature!".
I´ve checked the files (MD5 checksum) and all are OK.
FUS is 1.9.
I tested going from 8.2.150.0 to 8.2.170.o successfully, but, again, from 8.2.170.0 I cannot go to 8.3.150.0.
Plese help me with this issue.
1 ACCEPTED SOLUTION
Highlighted
Hi All. Thes issue is solved.
I go to the other suggested Cisco IOS: 8.5.140.0
Upgrade from 8.2.170.0 to 8.5.140.0 was successfull.
Thank a lot for your help.
Jorge
Note: upgrade from 8.2.170.0 to 8.3.x doesn´t work.
3 REPLIES 3
Highlighted
Hall of Fame Community Legend
Upgrade to 8.2.16X.X first. Don't go straight to 8.3.X.X.
Highlighted
HI Leo.
Thanks for your time.
Yes, I tested going from 8.2.150.0 to 8.2.170.0 successfully.
But, new upgrade from 8.2.170.0 to 8.3.150.0 goes into "Failure while validating the signature!".
After that, I tried upgrading from 8.2.170.0 to 8.3.143.0 with the same results.
In the Controller´s traps I have this: "Fail to upgrade wlc, versión before upgrade: 8.2.170.0, versión after upgade: 8.2.170.0, fail reason: file check fail."
I´ve checked MD5 checksum, and it is OK.
Regards.
Jorge
Highlighted
Jorge
