Evaluation to permanent License.
wrainwater
We have a clients office who currently has their controllers licensing set as the following:
They currently have 7 AP's. I want to verify there is no drop in connectivity. Once the evaluation period is over in 12 weeks will the other license kick in? Since its only for 5 AP's what will happen to the other two??
Jurgens L
Level 3
Level 3
Hi There,
Once your evaluation license expire you will need to set your base-ap-count license to high priority otherwise none of your AP’s will join the WLC.
When your base-ap-count is active again, the first 5 AP’s that associated first to the WLC will only be allowed and the remaining 2 won’t be able to join until one of the other 5 AP’s dissociate.
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
Jurgens L
Level 3
Level 3
Hi There,
You just saved us from getting a lot of future help desk tickets. Thank you.
No Worries,
One more thing worth mentioning is that should your eval license expire it won't kick your AP's immediately off the WLC. When the WLC reloads and comes back online, that's when the AP's will stop associating. So not ideal if you are in a scenario where there is a power failure and your eval license has expired.
jagan.chowdam
Level 4
Level 4
To prevent disruptions in operation, the controller does not switch licenses when an evaluation license expires. You must reboot the controller in order to return to a permanent license. Following a reboot, the controller defaults to the same feature set level as the expired evaluation license. If no permanent license at the same feature set level is installed, the controller uses a permanent license at another level or an unexpired evaluation license.
Thus, WLC gets 5 base-AP-count license as active and supports only 5 APs.
Hope this answers your question.
***Please rate all helpful responses***
Jagan
