Fastlane IEEE Standards
AndreasGrossen
Hi all
Can somebody explain me, which IEEE standard will be activated when Fastlane will be enabled?
And how can i test Fastlane with a IPhone?
Other Wireless - Mobility Subjects
Cheers
Andi
Scott Fella
Have you looked at the configuration guide? The guide will go over what fastlane was designed to do and what features gets enabled when fastlane is enabled.
https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/technotes/8-3/Optimizing_WiFi_Connectivity_and_Prioritizing_Business_Apps.pdf
-Scott
Hi Scott
Yeah i looked at the guid. But i heard just about 3 IEEE standard which will be activated wen Fastlane will be enabled. In the guid there are a lot more.
At least the guide explains the other changes that are made which you also need to be aware about:)
-Scott
