Popup Hotspot Using ISR 1000 with WiFi/LTE for Teleworkers and Micro Branchesr
Ask Me Anything – How to Enable Network Connectivity to Remote Workers
362
Highlighted
Beginner
Flex 7500 ver. 8.3.143.0 AP SSO HA Deployment
Hi Team.
we have two Flex 7500 WLC release 8.3.143.0 and we need to know is possible to configure AP/SSO HA scheme.
Everyone's tags (4)
5 REPLIES 5
Highlighted
Beginner
Re: Flex 7500 ver. 8.3.143.0 AP SSO HA Deployment
Yes it is possible, you need to use the redundancy port so it has to be layer 2 or if they are in the same rack just connect the two ports directly together.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-3/config-guide/b_cg83/b_cg83_chapter_01000.html
Highlighted
Beginner
 Mikey Boy: thanks for your answer.
We did that. But the AP SSO is never synchronized. We follow the step-by-step document.
Under what scenarios could the configuration fail?
Highlighted
Beginner
Highlighted
Beginner
Hi, are both WLC running the same code levels? What is the output of:
Show redundancy summary
Show redundancy detail
Highlighted
Beginner
OK Mikey Boy.
I schedule another visit to the client for this Monday 28 and I will take the "show" that you ask me.
Thank you very much again for the support.
Content for Community-Ad
Cisco COVID-19 Survey
