Flex Connect WLAN VLAN mapping
M.Netuschil5148
Hello Community,
what happens with the traffic when the VLAN on the remote site not exists?
I need a possibility to switch the traffic locally if the VLAN exists and if the VLAN locally not exists the traffic should be central switched to the controller.
Is this possible?
At the moment I receive an IP Adress only if the Central DHCP is set in the Flex Connect Group for the right WLAN, but the traffic doesn´t work.
The SSID is as follow configured:
- Flex Connect Local Switching active
- VLAN based central switching active
The FlexConnect Group is as follow configured:
- Group is created
- AP is added
- No WLAN to VLAN configured
All works fine it the VLAN is locally available but not when the VLAN exists.
Any possibilty to bring this alive?
Many thanks in advance,
Mario
Happy to hear that you find solution.
Please mark it as answered/ corrected question so that it will help to others.
M.Netuschil5148
Hi Community,
I found the answer to my question.
At this time it isn´t possible to use central and local switching at the same time.
So we must create a seperate SSID to use central switching.
Many thanks.
Best Regards,
Mario
