FlexConnect + Local Switching = No Network Access
Hi, I'm working with cisco wireless for the first time.
Im trying to setup some access points with multiple SSIDs/Vlans and to have the access points work even if the VWLC goes down (its on the same network as the APs) . I have a VWLC setup on a hyperV host with 3 networks on 3 different vlans.
I have confirmed that the VWLC subinterface ip's can be pinged from each network so I don't think its an issue with the vwlc the network adapter for it is in trunk mode and I made it using the powershell script on the cisco website.
The host is connected to a 2901 with an EHWIC-D-8ESG-P which is also where the APs are connected.
On the EHWIC-D-8ESG-P I have the following configured. the following for all 8 ports
interface GigabitEthernet0/1/0
switchport trunk native vlan 10
switchport trunk allowed vlan 1,2,10-12,1002-1005
switchport mode trunk
no ip address
On the VWLC I have for the access points
AP Mode FlexConnect
In the FlexConnect tab for the APs I have
VLAN Support checked and when I go into VLAN Mappings I can see my SSIDs which I have specified local mode assigned to their vlans
WLAN Id VLAN ID
Guest WiFi 12
On the interfaces I have setup
Interface Name VLAN IP Address
management 10 10.0.0.11
clientnet 11 10.0.1.11
dmznet 12 10.0.2.11
However when I connect any wifi client to the ssid I do not get an IP address from the DHCP server on this vlan.
I have not configured DHCP relay as there is a DHCP server on each vlan
The APs themselves get the following config
interface GigabitEthernet0.10
 encapsulation dot1Q 10 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 spanning-disabled
 no bridge-group 1 source-learning
interface GigabitEthernet0.11
 encapsulation dot1Q 11
 no ip route-cache
 bridge-group 5
 bridge-group 5 spanning-disabled
 no bridge-group 5 source-learning
interface GigabitEthernet0.12
 encapsulation dot1Q 12
 no ip route-cache
 bridge-group 6
 bridge-group 6 spanning-disabled
 no bridge-group 6 source-learning
Am I doing something wrong ?
5 Replies 5
Mikey Boy
Hi, on the SSID which you have set to flexconnect local switching you will have assigned an interface. If you go to the interfaces tab, under DHCP proxy mode what is that set to? I would set it to disable for my flexconnect SSIDs as normal practice.
If this is a live enviroment and that interface is used on any local mode SSID's you will need to be careful not to prevent other users being affected.
Yes everything under the DHCP section is disabled for the interface the wlans are on.
Primary DHCP Server  empty
Secondary DHCP Server  empty
DHCP Proxy Mode unticked
Enable DHCP Option 82 unticked
Enable DHCP Option 6 OpenDNS  unticked
So the local dhcp server on each vlan should be used, Yet whenever I connect a device to the ssid it gets stuck on APIPA.
I have a hyperv vm for testing that im assigning to the various vlans by changing the vlan tag and this gets the right IP address every time. But not anything going through the access points
It sounds like you have everything configured. Is there any DHCP snooping config present on the switching?
Quick solution to see what is happening, span the switchport with an AP on it during a client association. You should see DHCP traffic outside of the CAPWAP tunnel. This will verify instantly whether or not the DHCP traffic is happening locally on the switchport.
For an example if your AP VLAN is 10 , Domain WiFi is 12 and Guest VLAN is 13. Your AP switch port configuration should be as below.
Switch port mode trunk
Switch port trunk native VLAN 10
Switch port trunk allowed VLAN 10,12-13
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Because its a ehwic ive had to add the following default vlans
interface GigabitEthernet0/1/x
 no ip address
This should work correct ?
Because I can ping the VWLC interface ips from the respective network think the wlc is working fine.
Here is the network config on the AP.
bridge irb
interface Dot11Radio0
 antenna gain 0
 rxsop-threshold 85
 stbc
 ampdu transmit priority 1
 ampdu transmit priority 2
 ampdu transmit priority 3
 mbssid
 speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
 power client local
 packet retries 64 drop-packet
 station-role root
 no cdp enable
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no cdp enable
 bridge-group 6
 bridge-group 6 subscriber-loop-control
 bridge-group 6 block-unknown-source
 no bridge-group 6 unicast-flooding
interface Dot11Radio0.3
 encapsulation dot1Q 3
 no cdp enable
 bridge-group 5
 bridge-group 5 subscriber-loop-control
 bridge-group 5 block-unknown-source
 no bridge-group 5 unicast-flooding
interface Dot11Radio0.18
 encapsulation dot1Q 18
 no cdp enable
 bridge-group 2
 bridge-group 2 subscriber-loop-control
 bridge-group 2 spanning-disabled
 bridge-group 2 block-unknown-source
 no bridge-group 2 source-learning
 no bridge-group 2 unicast-flooding
interface Dot11Radio0.19
 encapsulation dot1Q 19
 no cdp enable
 bridge-group 3
 bridge-group 3 subscriber-loop-control
 bridge-group 3 spanning-disabled
 bridge-group 3 block-unknown-source
 no bridge-group 3 source-learning
 no bridge-group 3 unicast-flooding
interface Dot11Radio0.20
 encapsulation dot1Q 20
 no cdp enable
 bridge-group 4
 bridge-group 4 subscriber-loop-control
 bridge-group 4 spanning-disabled
 bridge-group 4 block-unknown-source
 no bridge-group 4 source-learning
 no bridge-group 4 unicast-flooding
interface Dot11Radio1
 antenna gain 0
 peakdetect
 rxsop-threshold 80
 stbc
 mbssid
 power client local
 station-role root
 no cdp enable
interface Dot11Radio1.2
 no cdp enable
 bridge-group 6
interface Dot11Radio1.18
 no cdp enable
 bridge-group 2
interface Dot11Radio1.19
 no cdp enable
 bridge-group 3
interface Dot11Radio1.20
 no cdp enable
 bridge-group 4
 no ip route-cache
 duplex auto
 speed auto
 no ip route-cache
 bridge-group 1
 no ip route-cache
 bridge-group 5
 no ip route-cache
 bridge-group 6
interface BVI1
 mac-address
 ip address dhcp client-id BVI1
 no ip route-cache
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
interface BVI2
 mac-address
 no ip address
interface BVI3
 mac-address
 no ip address
interface BVI4
 mac-address
 no ip address
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 route ip
bridge 3 route ip
bridge 4 route ip
