Guest Access disconnect
paul.tim681
Hello
on WLC 4400 Guest vlan is configured with local authentication, the users get disconnected after 10mins
were should i disable the option of 10mins restriction
thanks
Paul
Amjad Abdullah
Hello Paul,
check the session timeout in the advanced setting of the WLAN. It is by default 1800 seconds (30 minutes) but it is was possibly modified to 10 minutes. Check and let us know the feedback.
Amjad
Rating useful replies is more useful than saying "Thank you"
Hi Amjad
I see all default settings on within the WLAN
session time out 1800 sec
but still users get disconnected after 10 mins
thanks
Paul
does the client reconnect or try to reconnect after disconnect.
was the client idle when it got disconnect. if so increase the user idle timeout from controller tab. if that didn't work then get the debug client output to see what's going on.
