Guest Access Query
janesh_abey
Hi All,
Suppose we have 50 x WAN sites and we have 5 APs per  site.
If we to enable Guest Access for all sites, does  that mean we need  license of 250 for the anchor controller?
What is the best recommendation for provisioning licenses for guest anchor?
I have gone through the 7.0 config guide but apart from wired guest info not much help there.
Any help is very much appreciated.
Janesh
2 Accepted Solutions
Scott Fella
No. For guest anchoring you just need either a 4402-12 or 5508-12. Anything more is a waste. You see, the anchor doesn't manage any AP's just clients. The license are for ap count.
http://www.cisco.com/en/US/products/ps6366/products_qanda_item09186a00809ba482.shtml
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/emob41dg/ch10GuAc.html
-Scott
George Stefanick
I will piggy back off of Scott.
Where the licenses may come into play is if you have a 5508 and you do office extends. At that point, each O/E access point would take up one license on the DMZ controller. If you have plans to do OE you may want to keep that in mind.
6 Replies 6
Scott Fella
-Scott
Hi Scott,
Thanks a lot for the reply and the links.Its bit weird as to why why this info is not on config 7.0 guide
cheers,
J
George Stefanick
Hi Gergoe,
They are not interested in OE at this stage but it isa good pointer and many thanks for that.
cheers,
Janesh
Hi Janesh
what is that O/E term used for .. can you please explain or any one ?
Hi Muhammad,
OE stands for Office Eextended APs
here is the link for the config.
http://www.cisco.com/en/US/products/ps11579/products_tech_note09186a0080b7f10e.shtml
Enjoy!.
cheers
