Yes, you can and its very simple. On the guest WLAN click SECURITY --> LAYER 3 .. Then select WEB POLICY and then PASSTHROUGH ..
The guest will pass right through, so to speak. As for the landing page ...
Go SECURITY --> WEB AUTH --> WEB LOGON page and then you will see the redirect ..
If you find this helpful please kindly support the rating system.
