79
guest lan 5508
I have a WLC 5508(7.6.130.0) with 45 WAPs(3602i) setup with 1 WLAN (Raidus authenticated).  I would like to create a wireless guest lan.
Can I use the WAPs for both LANs or will I need to designate certain WAPs for this guest LAN?
Is there a guide to show me how to do this?
Thanks in advance.
charles
3 REPLIES 3
Highlighted
Rising star
You can create multiple
You can create multiple wireless LAN, refer a config example, creating internal and external ( guest ) WLAN
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/70937-guest-internal-wlan.html
Please refer this Link for
Please refer this Link for configuration examples
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-vlan/68100-wlan-controllers-vlans.html
Enthusiast
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/99470-config-wiredguest-00.html
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/69340-web-auth-config.html
http://www.cisco.com/c/en/us/td/docs/wireless/technology/guest_access/technical/reference/4-1/GAccess_41.html
Content for Community-Ad
August's Community Spotlight Awards
