12-26-2014 02:23 PM - edited 07-05-2021 02:11 AM
I have a 5508 core WLC with a 3850 as the local controller for an AP3G2-K9W8-M Access Point. The 3850 and the core WLC both have the wireless guest WLAN configured. My client can see the wireless LAN. When it tries to connect, it fails.
Can you give me debug commands that I can run on the AP, 3850, and/or WLC to try to determine why it won't connect?
12-27-2014 05:38 AM
This is what i understand regarding your setup
5508 Anchor Controller --- 3850 Foreign Controller --- AP -- Client.
You can run this command on controller to know why client is not connecting : debug client <MAC Address of Client>
Also create a test WLAN with no security to verify if the client connects or not ?
Ashish C
12-27-2014 06:08 AM
Thanks! I ran the debug - but I haven't found anything in it yet to help. Hopefully I have overlooked something that will help.
I created a test wlan with no security and it is not connecting either. Any additional thoughts would be greatly appreciated.
(Cisco Controller) >debug client 48-F8-B3-AE-EC-CF
(Cisco Controller) >*mmMaListen: Dec 26 19:31:19.493: 48:f8:b3:ae:ec:cf Adding mob
ile on Remote AP 00:00:00:00:00:00(0)
*mmMaListen: Dec 26 19:31:19.493: 48:f8:b3:ae:ec:cf Scheduling deletion of Mobile
Station: (callerId: 69) in 1 seconds
*osapiBsnTimer: Dec 26 19:31:20.461: 48:f8:b3:ae:ec:cf apfMsExpireCallback (apf_ms
.c:626) Expiring Mobile!
*apfReceiveTask: Dec 26 19:31:20.462: 48:f8:b3:ae:ec:cf pemApfDeleteMobileStation2
: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfReceiveTask: Dec 26 19:31:20.462: 48:f8:b3:ae:ec:cf 0.0.0.0 START (0) Deleted
mobile LWAPP rule on AP [00:00:00:00:00:00]
*apfReceiveTask: Dec 26 19:31:20.462: 48:f8:b3:ae:ec:cf Deleting mobile on AP 00:0
0:00:00:00:00(0)
*mmMaListen: Dec 26 19:31:20.485: 48:f8:b3:ae:ec:cf Adding mobile on Remote AP 00:
00:00:00:00:00(0)
*mmMaListen: Dec 26 19:31:20.485: 48:f8:b3:ae:ec:cf Scheduling deletion of Mobile
*osapiBsnTimer: Dec 26 19:31:21.461: 48:f8:b3:ae:ec:cf apfMsExpireCallback (apf_ms
*apfReceiveTask: Dec 26 19:31:21.462: 48:f8:b3:ae:ec:cf pemApfDeleteMobileStation2
*apfReceiveTask: Dec 26 19:31:21.462: 48:f8:b3:ae:ec:cf 0.0.0.0 START (0) Deleted
*apfReceiveTask: Dec 26 19:31:21.462: 48:f8:b3:ae:ec:cf Deleting mobile on AP 00:0
0:00:00:00:00(0)
*mmMaListen: Dec 26 19:31:21.476: 48:f8:b3:ae:ec:cf Adding mobile on Remote AP 00:
00:00:00:00:00(0)
*mmMaListen: Dec 26 19:31:21.476: 48:f8:b3:ae:ec:cf Scheduling deletion of Mobile
*osapiBsnTimer: Dec 26 19:31:22.461: 48:f8:b3:ae:ec:cf apfMsExpireCallback (apf_ms
*apfReceiveTask: Dec 26 19:31:22.462: 48:f8:b3:ae:ec:cf pemApfDeleteMobileStation2
*apfReceiveTask: Dec 26 19:31:22.462: 48:f8:b3:ae:ec:cf 0.0.0.0 START (0) Deleted
*apfReceiveTask: Dec 26 19:31:22.462: 48:f8:b3:ae:ec:cf Deleting mobile on AP 00:0
0:00:00:00:00(0)
12-27-2014 06:23 AM
Please attach show tech from both controller and AP.
Also check if you have MAC Filtering enabled on the WLAN under layer 2 security ?
12-27-2014 06:31 AM
Thanks - MAC Filtering is not enabled. Will take a bit to get the show tech.
12-27-2014 07:43 AM
12-27-2014 08:08 AM
Have you enabled new mobility on 5508 controller ?
Both the controller are in same mobility group and there control and data path is up as well?
Also check this document to configure mobility : http://www.cisco.com/c/en/us/td/docs/wireless/technology/5760_deploy/CT5760_Controller_Deployment_Guide/Mobility_Architecture.html
Configuring Mobility on 5508 controller: http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-5/config_guide/b_cg75/b_cg75_chapter_010001100.html
12-27-2014 08:21 AM
Thanks, I will review those docs and look into your questions.
