06-26-2012 07:12 AM - edited 07-03-2021 10:20 PM
I have Guest WLAN and i want to redirect all the traffice to Proxy Server. We use Cisco Ironport.
Cisco proxy Ironport has the ip 10.X.X.X.
We also have NCS Server. Can anybody tells me where i can configure this
best regards and thanks in advance
06-26-2012 08:59 AM
Nothing on the WLC to configure. Take a look at this thread
https://supportforums.cisco.com/thread/2126486
06-27-2012 01:44 AM
Muzaffar:
If you have web-auth configured you may have problems with the redirection if the users are using manual proxy server configured.
For that, you better enable WebAuth proxy redirection on wireless controller.
Here is the config example
http://www.cisco.com/en/US/products/ps10315/products_configuration_example09186a0080b8a909.shtml
Amjad
