Beginner
handover problem
Hi!
I have a  WLC 5508 and 25  LAP 1041. I use two wifi, one with RADIUS for data and other with wpa-psk for voip. The problem is the voip conectivity is broken.
How can i improve the handover?
The NEC recomendation does not help me anything.
thanks!
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: handover problem
well In the debugs we have reassociation frames sent by the client upon romaing in both cases which reduces the chance of having coverage hole issues.
Also I can see that we don't have reauth again , the PKC seems to be working very well.
11 REPLIES 11
handover problem
You have to make sure that you have overlapping of at least 20 % between Adjacent APs.
There are so many things to be checked, but for the time being please specify the model of phone
you are using.
Beginner
handover problem
NEC MH240 wireless IP telephone. I think the overlap is less than 20%. The APs are LAP1041
handover problem
does nec do pkc or okc.
With voice it is expected to have roaming issue with psk only, it is recommeded to use WPA2 with 802.1X+CCKM for fast secure roaming. But NEC doesn't look like it supports cckm/ccx from below link.
http://www.cisco.com/web/partners/pr46/pr147/partners_pgm_partners_0900aecd800a7907.html
English version
http://www.necux5000.com/dealer_area/documents/mobility_solutions/wifi_handset/ubux5009003an.pdf
Known Service Conditions and/or Limitations
Service Conditions/Limitations that may affect voice quality:
1. CISCO does not support standard based CAC, a method to limit the maximum number of
clients (MH240 handsets) per radio. This could cause issues such as degradation to voice
quality if there are over subscriptions on a particular access point
answer
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_2.html#wp912730
KTS-Based CAC Support for NEC
Key Telephone System (KTS)-based CAC is a protocol that is used in NEC MH240 wireless IP telephones. You can configure the controller to support CAC on KTS-based SIP clients to process bandwidth request messages from clients, to allocate the required bandwidth on the AP radio, and to handle other messages that are part of the protocol.
Beginner
handover problem
I think the problem is the coverage and overlap. But, the NEC device, or any Smartphone, is associated with a AP (for example, in front of office on the first floor), When I enter the building, the NEC can not associate with other APs, or is slow to associate, until he entered the office, on the first floor.
Two differents wifi affects on the performance of associate or handover?
handover problem
did you follow the nec reco guide for cisco gear.
in high density environment many client would roam between APs without an issue so two clients should not be an issue. Fix the coverage and overlap, it will help smooth rf roaming but can't help on smooth hand off, however psk is still quicker.
while reproducing the issue get the below output.
WLC>debug client
Beginner
handover problem
Thank you!
i try to do the command "debug client". Two question: Where is the "KTS-Based CAC Support for NEC" option?
Is the handover/handoff affected by the two differents wifi broadcasting?
handover problem
When running the debug client
if you see reassociation sent from the client upon roaming there shouldn't be any overlapping issue
if you see association frame sent to the new ap from the target client , then yes there is coverage hole.
Cheers
Highlighted
Beginner
handover problem
Thank you. Well, it's the first time i use that tool. How to i see the reassociation or frames?
handover problem
have the following command enabled:
debug client < mac address >
associate to AP1 then move toward AP2 while the debug is running to reproduce the problem.
Attach the resulting output here.
You should see the reassociation in the debug output.
Beginner
Hello:
I send you two logs.
First log:
(Cisco Controller) debug>*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1
f Reassociation received from mobile on AP 3c:ce:73:f9:2e:c0
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
hanging IPv4 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_po
licy.c:1697)
hanging IPv6 ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_po
licy.c:1864)
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f Applying site-specific
Local Bridging override for station 00:60:b9:0d:ec:1f - vapId 2, site 'default-g
roup', interface 'pvoz'
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f Applying Local Bridging
Interface Policy for station 00:60:b9:0d:ec:1f - vlan 106, interface id 12, int
erface 'pvoz'
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f processSsidIE  statusCo
de is 0 and status is 0
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f processSsidIE  ssid_don
e_flag is 0 finish_flag is 0
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f STA - rates (8): 139 22
24 36 48 72 96 108 12 18 0 0 0 0 0 0
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f suppRates  statusCode i
s 0 and gotSuppRatesElement is 1
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f STA - rates (10): 139 2
2 24 36 48 72 96 108 12 18 0 0 0 0 0 0
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f extSuppRates  statusCod
e is 0 and gotExtSuppRatesElement is 1
*apfMsConnTask_6: Jun 27 11:27:36.722: 00:60:b9:0d:ec:1f Processing RSN IE type
48, length 20 for mobile 00:60:b9:0d:ec:1f
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f pemApfDeleteMobileStati
on2: APF_MS_PEM_WAIT_L2_AUTH_COMPLETE = 0.
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) D
eleted mobile LWAPP rule on AP [3c:ce:73:f8:e1:00]
*pemReceiveTask: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f 10.160.91.51 Removed NPU
entry.
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f Updated location for st
ation old AP 3c:ce:73:f8:e1:00-0, new AP 3c:ce:73:f9:2e:c0-0
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f apfMsRunStateDec
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f apfMs1xStateDec
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
hange state to START (0) last state RUN (20)
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f pemApfAddMobileStation2
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f 10.160.91.51 START (0)
Initializing policy
Change state to AUTHCHECK (2) last state RUN (20)
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f 10.160.91.51 AUTHCHECK
(2) Change state to 8021X_REQD (3) last state RUN (20)
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_REQD
(3) DHCP required on AP 3c:ce:73:f9:2e:c0 vapId 2 apVapId 2for this client
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f Not Using WMM Complianc
e code qosCap 00
(3) Plumbed mobile LWAPP rule on AP 3c:ce:73:f9:2e:c0 vapId 2 apVapId 2
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f apfPemAddUser2 (apf_pol
icy.c:268) Changing state for mobile 00:60:b9:0d:ec:1f on AP 3c:ce:73:f9:2e:c0 f
rom Associated to Associated
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f Scheduling deletion of
Mobile Station:  (callerId: 49) in 1800 seconds
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f Sending Assoc Response
to station on BSSID 3c:ce:73:f9:2e:c0 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_6: Jun 27 11:27:36.723: 00:60:b9:0d:ec:1f apfProcessAssocReq (apf
_80211.c:6290) Changing state for mobile 00:60:b9:0d:ec:1f on AP 3c:ce:73:f9:2e:
c0 from Associated to Associated
*dot1xMsgTask: Jun 27 11:27:36.725: 00:60:b9:0d:ec:1f Creating a PKC PMKID Cache
entry for station 00:60:b9:0d:ec:1f (RSN 2)
*dot1xMsgTask: Jun 27 11:27:36.725: 00:60:b9:0d:ec:1f Resetting MSCB PMK Cache E
ntry 0 for station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:27:36.725: 00:60:b9:0d:ec:1f Removing BSSID 3c:ce:73:f8
:e1:01 from PMKID cache of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:27:36.725: 00:60:b9:0d:ec:1f Setting active key cache i
ndex 0 ---> 8
ndex 8 ---> 0
*dot1xMsgTask: Jun 27 11:27:36.725: 00:60:b9:0d:ec:1f Adding BSSID 3c:ce:73:f9:2
e:c1 to PMKID cache at index 0 for station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:27:36.725: New PMKID: (16)
*dot1xMsgTask: Jun 27 11:27:36.725:      [0000] 74 1f ee 29 2e 8d fc df 33 97 9a
33 d6 57 d8 be
*dot1xMsgTask: Jun 27 11:27:36.725: 00:60:b9:0d:ec:1f Initiating RSN PSK to mobi
*dot1xMsgTask: Jun 27 11:27:36.726: 00:60:b9:0d:ec:1f dot1x - moving mobile 00:6
0:b9:0d:ec:1f into Force Auth state
*dot1xMsgTask: Jun 27 11:27:36.726: 00:60:b9:0d:ec:1f Skipping EAP-Success to mo
*dot1xMsgTask: Jun 27 11:27:36.726: 00:60:b9:0d:ec:1f Found an cache entry for B
SSID 3c:ce:73:f9:2e:c1 in PMKID cache at index 0 of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:27:36.726: Including PMKID in M1  (16)
*dot1xMsgTask: Jun 27 11:27:36.726:      [0000] 74 1f ee 29 2e 8d fc df 33 97 9a
33 d6 57 d8 be
*dot1xMsgTask: Jun 27 11:27:36.726: 00:60:b9:0d:ec:1f Starting key exchange to m
obile 00:60:b9:0d:ec:1f, data packets will be dropped
*dot1xMsgTask: Jun 27 11:27:36.726: 00:60:b9:0d:ec:1f Sending EAPOL-Key Message
to mobile 00:60:b9:0d:ec:1f
                              state INITPMK (message 1), replay counter 00.00.00
.00.00.00.00.00
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.767: 00:60:b9:0d:ec:1f Received EAPOL-Key f
rom mobile 00:60:b9:0d:ec:1f
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.767: 00:60:b9:0d:ec:1f Received EAPOL-key i
n PTK_START state (message 2) from mobile 00:60:b9:0d:ec:1f
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.767: 00:60:b9:0d:ec:1f Stopping retransmiss
ion timer for mobile 00:60:b9:0d:ec:1f
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.767: 00:60:b9:0d:ec:1f Sending the random G
TK in M3 for WPA2 client  00:60:b9:0d:ec:1f
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.767: 00:60:b9:0d:ec:1f Sending EAPOL-Key Me
ssage to mobile 00:60:b9:0d:ec:1f
                                    state PTKINITNEGOTIATING (message 3), replay
counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.771: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.771: 00:60:b9:0d:ec:1f Received EAPOL-key i
n PTKINITNEGOTIATING state (message 4) from mobile 00:60:b9:0d:ec:1f
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.771: 00:60:b9:0d:ec:1f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.771: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_R
EQD (3) Change state to L2AUTHCOMPLETE (4) last state RUN (20)
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.772: 00:60:b9:0d:ec:1f 10.160.91.51 L2AUTHC
OMPLETE (4) DHCP required on AP 3c:ce:73:f9:2e:c0 vapId 2 apVapId 2for this clie
nt
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.772: 00:60:b9:0d:ec:1f Not Using WMM Compli
ance code qosCap 00
OMPLETE (4) Plumbed mobile LWAPP rule on AP 3c:ce:73:f9:2e:c0 vapId 2 apVapId 2
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.772: 00:60:b9:0d:ec:1f apfMsRunStateInc
OMPLETE (4) Change state to RUN (20) last state RUN (20)
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.772: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20
) Reached PLUMBFASTPATH: from line 5362
*Dot1x_: Jun 27 11:27:36.772: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) Adding Fas
t Path rule
  type = Airespace AP Client
  on AP 3c:ce:73:f9:2e:c0, slot 0, interface = 13, QOS = 2
  IPv4 ACL ID = 255, IPv6 ACL ID =
) Fast Path rule (contd...) 802.1P = 0, DSCP = 0, TokenID = 7006  Local Bridging
Vlan = 106, Local Bridging intf id = 12
) Successfully plumbed mobile rule (IPv4 ACL ID 255, IPv6 ACL ID 255)
*Dot1x_NW_MsgTask_7: Jun 27 11:27:36.772: 00:60:b9:0d:ec:1f Stopping retransmiss
*pemReceiveTask: Jun 27 11:27:36.772: 00:60:b9:0d:ec:1f 10.160.91.51 Added NPU e
ntry of type 1, dtlFlags 0x0
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f Reassociation received
from mobile on AP 3c:ce:73:f9:13:e0
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
licy.c:1697)
licy.c:1864)
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f Applying site-specific
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f Applying Local Bridging
erface 'pvoz'
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f processSsidIE  statusCo
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f processSsidIE  ssid_don
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f STA - rates (8): 139 22
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f suppRates  statusCode i
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f STA - rates (10): 139 2
*apfMsConnTask_3: Jun 27 11:29:25.570: 00:60:b9:0d:ec:1f extSuppRates  statusCod
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f Processing RSN IE type
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f pemApfDeleteMobileStati
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) D
eleted mobile LWAPP rule on AP [3c:ce:73:f9:2e:c0]
*pemReceiveTask: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f 10.160.91.51 Removed NPU
entry.
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f Updated location for st
ation old AP 3c:ce:73:f9:2e:c0-0, new AP 3c:ce:73:f9:13:e0-0
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f apfMsRunStateDec
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f apfMs1xStateDec
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f pemApfAddMobileStation2
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f 10.160.91.51 START (0)
Initializing policy
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f 10.160.91.51 AUTHCHECK
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_REQD
(3) DHCP required on AP 3c:ce:73:f9:13:e0 vapId 2 apVapId 2for this client
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f Not Using WMM Complianc
e code qosCap 00
(3) Plumbed mobile LWAPP rule on AP 3c:ce:73:f9:13:e0 vapId 2 apVapId 2
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f apfPemAddUser2 (apf_pol
icy.c:268) Changing state for mobile 00:60:b9:0d:ec:1f on AP 3c:ce:73:f9:13:e0 f
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f Scheduling deletion of
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f Sending Assoc Response
to station on BSSID 3c:ce:73:f9:13:e0 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_3: Jun 27 11:29:25.571: 00:60:b9:0d:ec:1f apfProcessAssocReq (apf
_80211.c:6290) Changing state for mobile 00:60:b9:0d:ec:1f on AP 3c:ce:73:f9:13:
e0 from Associated to Associated
*dot1xMsgTask: Jun 27 11:29:25.573: 00:60:b9:0d:ec:1f Creating a PKC PMKID Cache
*dot1xMsgTask: Jun 27 11:29:25.573: 00:60:b9:0d:ec:1f Resetting MSCB PMK Cache E
*dot1xMsgTask: Jun 27 11:29:25.573: 00:60:b9:0d:ec:1f Removing BSSID 3c:ce:73:f9
:2e:c1 from PMKID cache of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:29:25.573: 00:60:b9:0d:ec:1f Setting active key cache i
ndex 0 ---> 8
ndex 8 ---> 0
*dot1xMsgTask: Jun 27 11:29:25.573: 00:60:b9:0d:ec:1f Adding BSSID 3c:ce:73:f9:1
3:e1 to PMKID cache at index 0 for station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:29:25.573: New PMKID: (16)
*dot1xMsgTask: Jun 27 11:29:25.573:      [0000] 8e d8 80 65 d2 75 1e 24 a7 a1 ab
8b 7e 72 e1 6a
*dot1xMsgTask: Jun 27 11:29:25.573: 00:60:b9:0d:ec:1f Initiating RSN PSK to mobi
*dot1xMsgTask: Jun 27 11:29:25.573: 00:60:b9:0d:ec:1f dot1x - moving mobile 00:6
*dot1xMsgTask: Jun 27 11:29:25.574: 00:60:b9:0d:ec:1f Skipping EAP-Success to mo
*dot1xMsgTask: Jun 27 11:29:25.574: 00:60:b9:0d:ec:1f Found an cache entry for B
SSID 3c:ce:73:f9:13:e1 in PMKID cache at index 0 of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:29:25.574: Including PMKID in M1  (16)
*dot1xMsgTask: Jun 27 11:29:25.574:      [0000] 8e d8 80 65 d2 75 1e 24 a7 a1 ab
8b 7e 72 e1 6a
*dot1xMsgTask: Jun 27 11:29:25.574: 00:60:b9:0d:ec:1f Starting key exchange to m
*dot1xMsgTask: Jun 27 11:29:25.574: 00:60:b9:0d:ec:1f Sending EAPOL-Key Message
.00.00.00.00.00
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.634: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.634: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.634: 00:60:b9:0d:ec:1f Stopping retransmiss
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.634: 00:60:b9:0d:ec:1f Sending the random G
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.634: 00:60:b9:0d:ec:1f Sending EAPOL-Key Me
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.645: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.645: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.645: 00:60:b9:0d:ec:1f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.645: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_R
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.645: 00:60:b9:0d:ec:1f 10.160.91.51 L2AUTHC
OMPLETE (4) DHCP required on AP 3c:ce:73:f9:13:e0 vapId 2 apVapId 2for this clie
nt
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.645: 00:60:b9:0d:ec:1f Not Using WMM Compli
ance code qosCap 00
OMPLETE (4) Plumbed mobile LWAPP rule on AP 3c:ce:73:f9:13:e0 vapId 2 apVapId 2
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.645: 00:60:b9:0d:ec:1f apfMsRunStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.646: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20
*Dot1x_: Jun 27 11:29:25.646: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) Adding Fas
t Path rule
  on AP 3c:ce:73:f9:13:e0, slot 0, interface = 13, QOS = 2
*Dot1x_NW_MsgTask_7: Jun 27 11:29:25.646: 00:60:b9:0d:ec:1f Stopping retransmiss
*pemReceiveTask: Jun 27 11:29:25.646: 00:60:b9:0d:ec:1f 10.160.91.51 Added NPU e
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f Reassociation received
from mobile on AP 2c:36:f8:e9:8b:70
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
licy.c:1697)
licy.c:1864)
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f Applying site-specific
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f Applying Local Bridging
erface 'pvoz'
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f processSsidIE  statusCo
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f processSsidIE  ssid_don
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f STA - rates (8): 139 22
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f suppRates  statusCode i
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f STA - rates (10): 139 2
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f extSuppRates  statusCod
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f Processing RSN IE type
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f pemApfDeleteMobileStati
*apfMsConnTask_0: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) D
eleted mobile LWAPP rule on AP [3c:ce:73:f9:13:e0]
*pemReceiveTask: Jun 27 11:29:36.736: 00:60:b9:0d:ec:1f 10.160.91.51 Removed NPU
entry.
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f Updated location for st
ation old AP 3c:ce:73:f9:13:e0-0, new AP 2c:36:f8:e9:8b:70-0
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f apfMsRunStateDec
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f apfMs1xStateDec
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f pemApfAddMobileStation2
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f 10.160.91.51 START (0)
Initializing policy
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f 10.160.91.51 AUTHCHECK
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_REQD
(3) DHCP required on AP 2c:36:f8:e9:8b:70 vapId 2 apVapId 2for this client
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f Not Using WMM Complianc
e code qosCap 00
(3) Plumbed mobile LWAPP rule on AP 2c:36:f8:e9:8b:70 vapId 2 apVapId 2
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f apfPemAddUser2 (apf_pol
icy.c:268) Changing state for mobile 00:60:b9:0d:ec:1f on AP 2c:36:f8:e9:8b:70 f
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f Scheduling deletion of
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f Sending Assoc Response
to station on BSSID 2c:36:f8:e9:8b:70 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_0: Jun 27 11:29:36.737: 00:60:b9:0d:ec:1f apfProcessAssocReq (apf
_80211.c:6290) Changing state for mobile 00:60:b9:0d:ec:1f on AP 2c:36:f8:e9:8b:
70 from Associated to Associated
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Creating a PKC PMKID Cache
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Resetting MSCB PMK Cache E
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Removing BSSID 3c:ce:73:f9
:13:e1 from PMKID cache of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Setting active key cache i
ndex 0 ---> 8
ndex 8 ---> 0
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Adding BSSID 2c:36:f8:e9:8
b:71 to PMKID cache at index 0 for station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:29:36.739: New PMKID: (16)
*dot1xMsgTask: Jun 27 11:29:36.739:      [0000] e1 7e 9b 2b fe 9d 4f 61 52 08 05
70 9e 9d 5a 8c
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Initiating RSN PSK to mobi
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f dot1x - moving mobile 00:6
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Skipping EAP-Success to mo
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Found an cache entry for B
SSID 2c:36:f8:e9:8b:71 in PMKID cache at index 0 of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:29:36.739: Including PMKID in M1  (16)
70 9e 9d 5a 8c
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Starting key exchange to m
*dot1xMsgTask: Jun 27 11:29:36.739: 00:60:b9:0d:ec:1f Sending EAPOL-Key Message
.00.00.00.00.00
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.781: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.781: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.781: 00:60:b9:0d:ec:1f Stopping retransmiss
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.781: 00:60:b9:0d:ec:1f Sending the random G
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.781: 00:60:b9:0d:ec:1f Sending EAPOL-Key Me
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.785: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.785: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.785: 00:60:b9:0d:ec:1f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.785: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_R
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.785: 00:60:b9:0d:ec:1f 10.160.91.51 L2AUTHC
OMPLETE (4) DHCP required on AP 2c:36:f8:e9:8b:70 vapId 2 apVapId 2for this clie
nt
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.785: 00:60:b9:0d:ec:1f Not Using WMM Compli
ance code qosCap 00
OMPLETE (4) Plumbed mobile LWAPP rule on AP 2c:36:f8:e9:8b:70 vapId 2 apVapId 2
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.786: 00:60:b9:0d:ec:1f apfMsRunStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.786: 00:60:b9:0d:ec:1f 10.160.91.51 L2AUTHC
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.786: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20
*Dot1x_: Jun 27 11:29:36.786: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) Adding Fas
t Path rule
  on AP 2c:36:f8:e9:8b:70, slot 0, interface = 13, QOS = 2
*Dot1x_NW_MsgTask_7: Jun 27 11:29:36.786: 00:60:b9:0d:ec:1f Stopping retransmiss
Second log:
*dot1xMsgTask: Jun 27 11:43:35.430: 00:60:b9:0d:ec:1f Found an cache entry for B
SSID 3c:ce:73:95:40:01 in PMKID cache at index 0 of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:43:35.430: Including PMKID in M1  (16)
*dot1xMsgTask: Jun 27 11:43:35.430:      [0000] ac 0b 62 a3 0d cd 4f 08 5c 29 2d
d0 10 7c a8 e5
*dot1xMsgTask: Jun 27 11:43:35.430: 00:60:b9:0d:ec:1f Starting key exchange to m
*dot1xMsgTask: Jun 27 11:43:35.430: 00:60:b9:0d:ec:1f Sending EAPOL-Key Message
.00.00.00.00.00
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.470: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.470: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.470: 00:60:b9:0d:ec:1f Stopping retransmiss
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.470: 00:60:b9:0d:ec:1f Sending the random G
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.470: 00:60:b9:0d:ec:1f Sending EAPOL-Key Me
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_R
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f 10.160.91.51 L2AUTHC
OMPLETE (4) DHCP required on AP 3c:ce:73:95:40:00 vapId 2 apVapId 2for this clie
nt
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f Not Using WMM Compli
ance code qosCap 00
OMPLETE (4) Plumbed mobile LWAPP rule on AP 3c:ce:73:95:40:00 vapId 2 apVapId 2
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f apfMsRunStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20
*Dot1x_: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) Adding Fas
t Path rule
  on AP 3c:ce:73:95:40:00, slot 0, interface = 13, QOS = 2
*Dot1x_NW_MsgTask_7: Jun 27 11:43:35.474: 00:60:b9:0d:ec:1f Stopping retransmiss
*pemReceiveTask: Jun 27 11:43:35.475: 00:60:b9:0d:ec:1f 10.160.91.51 Added NPU e
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f Reassociation received
from mobile on AP c8:f9:f9:5b:0e:e0
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
licy.c:1697)
licy.c:1864)
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f Applying site-specific
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f Applying Local Bridging
erface 'pvoz'
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f processSsidIE  statusCo
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f processSsidIE  ssid_don
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f STA - rates (8): 139 22
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f suppRates  statusCode i
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f STA - rates (10): 139 2
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f extSuppRates  statusCod
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f Processing RSN IE type
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f pemApfDeleteMobileStati
*apfMsConnTask_5: Jun 27 11:45:13.475: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) D
eleted mobile LWAPP rule on AP [3c:ce:73:95:40:00]
*pemReceiveTask: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f 10.160.91.51 Removed NPU
entry.
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f Updated location for st
ation old AP 3c:ce:73:95:40:00-0, new AP c8:f9:f9:5b:0e:e0-0
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f apfMsRunStateDec
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f apfMs1xStateDec
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f pemApfAddMobileStation2
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f 10.160.91.51 START (0)
Initializing policy
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f 10.160.91.51 AUTHCHECK
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_REQD
(3) DHCP required on AP c8:f9:f9:5b:0e:e0 vapId 2 apVapId 2for this client
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f Not Using WMM Complianc
e code qosCap 00
(3) Plumbed mobile LWAPP rule on AP c8:f9:f9:5b:0e:e0 vapId 2 apVapId 2
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f apfPemAddUser2 (apf_pol
icy.c:268) Changing state for mobile 00:60:b9:0d:ec:1f on AP c8:f9:f9:5b:0e:e0 f
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f Scheduling deletion of
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f Sending Assoc Response
to station on BSSID c8:f9:f9:5b:0e:e0 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_5: Jun 27 11:45:13.476: 00:60:b9:0d:ec:1f apfProcessAssocReq (apf
_80211.c:6290) Changing state for mobile 00:60:b9:0d:ec:1f on AP c8:f9:f9:5b:0e:
*dot1xMsgTask: Jun 27 11:45:13.478: 00:60:b9:0d:ec:1f Creating a PKC PMKID Cache
*dot1xMsgTask: Jun 27 11:45:13.478: 00:60:b9:0d:ec:1f Resetting MSCB PMK Cache E
*dot1xMsgTask: Jun 27 11:45:13.478: 00:60:b9:0d:ec:1f Removing BSSID 3c:ce:73:95
:40:01 from PMKID cache of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:13.478: 00:60:b9:0d:ec:1f Setting active key cache i
ndex 0 ---> 8
ndex 8 ---> 0
*dot1xMsgTask: Jun 27 11:45:13.478: 00:60:b9:0d:ec:1f Adding BSSID c8:f9:f9:5b:0
e:e1 to PMKID cache at index 0 for station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:13.478: New PMKID: (16)
*dot1xMsgTask: Jun 27 11:45:13.478:      [0000] 09 1d 27 25 44 d4 32 7b 4a dc d8
46 6d 8a d4 92
*dot1xMsgTask: Jun 27 11:45:13.478: 00:60:b9:0d:ec:1f Initiating RSN PSK to mobi
*dot1xMsgTask: Jun 27 11:45:13.478: 00:60:b9:0d:ec:1f dot1x - moving mobile 00:6
*dot1xMsgTask: Jun 27 11:45:13.479: 00:60:b9:0d:ec:1f Skipping EAP-Success to mo
*dot1xMsgTask: Jun 27 11:45:13.479: 00:60:b9:0d:ec:1f Found an cache entry for B
SSID c8:f9:f9:5b:0e:e1 in PMKID cache at index 0 of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:13.479: Including PMKID in M1  (16)
*dot1xMsgTask: Jun 27 11:45:13.479:      [0000] 09 1d 27 25 44 d4 32 7b 4a dc d8
46 6d 8a d4 92
*dot1xMsgTask: Jun 27 11:45:13.479: 00:60:b9:0d:ec:1f Starting key exchange to m
*dot1xMsgTask: Jun 27 11:45:13.479: 00:60:b9:0d:ec:1f Sending EAPOL-Key Message
.00.00.00.00.00
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.536: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.536: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.536: 00:60:b9:0d:ec:1f Stopping retransmiss
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.537: 00:60:b9:0d:ec:1f Sending the random G
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.537: 00:60:b9:0d:ec:1f Sending EAPOL-Key Me
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_R
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f 10.160.91.51 L2AUTHC
OMPLETE (4) DHCP required on AP c8:f9:f9:5b:0e:e0 vapId 2 apVapId 2for this clie
nt
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f Not Using WMM Compli
ance code qosCap 00
OMPLETE (4) Plumbed mobile LWAPP rule on AP c8:f9:f9:5b:0e:e0 vapId 2 apVapId 2
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f apfMsRunStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20
*Dot1x_: Jun 27 11:45:13.541: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) Adding Fas
t Path rule
  on AP c8:f9:f9:5b:0e:e0, slot 0, interface = 13, QOS = 2
*Dot1x_NW_MsgTask_7: Jun 27 11:45:13.542: 00:60:b9:0d:ec:1f Stopping retransmiss
*pemReceiveTask: Jun 27 11:45:13.543: 00:60:b9:0d:ec:1f 10.160.91.51 Added NPU e
*apfMsConnTask_2: Jun 27 11:45:34.850: 00:60:b9:0d:ec:1f Reassociation received
from mobile on AP c8:f9:f9:2b:69:20
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
licy.c:1697)
licy.c:1864)
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f Applying site-specific
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f Applying Local Bridging
erface 'pvoz'
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f processSsidIE  statusCo
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f processSsidIE  ssid_don
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f STA - rates (8): 139 22
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f suppRates  statusCode i
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f STA - rates (10): 139 2
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f extSuppRates  statusCod
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f Processing RSN IE type
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f pemApfDeleteMobileStati
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) D
eleted mobile LWAPP rule on AP [c8:f9:f9:5b:0e:e0]
*pemReceiveTask: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f 10.160.91.51 Removed NPU
entry.
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f Updated location for st
ation old AP c8:f9:f9:5b:0e:e0-0, new AP c8:f9:f9:2b:69:20-0
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f apfMsRunStateDec
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f apfMs1xStateDec
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f pemApfAddMobileStation2
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f 10.160.91.51 START (0)
Initializing policy
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f 10.160.91.51 AUTHCHECK
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_REQD
(3) DHCP required on AP c8:f9:f9:2b:69:20 vapId 2 apVapId 2for this client
*apfMsConnTask_2: Jun 27 11:45:34.851: 00:60:b9:0d:ec:1f Not Using WMM Complianc
e code qosCap 00
*apfMsConnTask_2: Jun 27 11:45:34.852: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_REQD
(3) Plumbed mobile LWAPP rule on AP c8:f9:f9:2b:69:20 vapId 2 apVapId 2
*apfMsConnTask_2: Jun 27 11:45:34.852: 00:60:b9:0d:ec:1f apfPemAddUser2 (apf_pol
icy.c:268) Changing state for mobile 00:60:b9:0d:ec:1f on AP c8:f9:f9:2b:69:20 f
*apfMsConnTask_2: Jun 27 11:45:34.852: 00:60:b9:0d:ec:1f Scheduling deletion of
*apfMsConnTask_2: Jun 27 11:45:34.852: 00:60:b9:0d:ec:1f Sending Assoc Response
to station on BSSID c8:f9:f9:2b:69:20 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_2: Jun 27 11:45:34.852: 00:60:b9:0d:ec:1f apfProcessAssocReq (apf
_80211.c:6290) Changing state for mobile 00:60:b9:0d:ec:1f on AP c8:f9:f9:2b:69:
20 from Associated to Associated
*dot1xMsgTask: Jun 27 11:45:34.854: 00:60:b9:0d:ec:1f Creating a PKC PMKID Cache
*dot1xMsgTask: Jun 27 11:45:34.854: 00:60:b9:0d:ec:1f Resetting MSCB PMK Cache E
*dot1xMsgTask: Jun 27 11:45:34.854: 00:60:b9:0d:ec:1f Removing BSSID c8:f9:f9:5b
:0e:e1 from PMKID cache of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:34.854: 00:60:b9:0d:ec:1f Setting active key cache i
ndex 0 ---> 8
ndex 8 ---> 0
*dot1xMsgTask: Jun 27 11:45:34.854: 00:60:b9:0d:ec:1f Adding BSSID c8:f9:f9:2b:6
9:21 to PMKID cache at index 0 for station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:34.854: New PMKID: (16)
*dot1xMsgTask: Jun 27 11:45:34.854:      [0000] 9f c0 6d 61 b8 cc 1a 53 0f 7d 74
3f 25 9f b8 14
*dot1xMsgTask: Jun 27 11:45:34.854: 00:60:b9:0d:ec:1f Initiating RSN PSK to mobi
*dot1xMsgTask: Jun 27 11:45:34.854: 00:60:b9:0d:ec:1f dot1x - moving mobile 00:6
*dot1xMsgTask: Jun 27 11:45:34.855: 00:60:b9:0d:ec:1f Skipping EAP-Success to mo
*dot1xMsgTask: Jun 27 11:45:34.855: 00:60:b9:0d:ec:1f Found an cache entry for B
SSID c8:f9:f9:2b:69:21 in PMKID cache at index 0 of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:34.855: Including PMKID in M1  (16)
*dot1xMsgTask: Jun 27 11:45:34.855:      [0000] 9f c0 6d 61 b8 cc 1a 53 0f 7d 74
3f 25 9f b8 14
*dot1xMsgTask: Jun 27 11:45:34.855: 00:60:b9:0d:ec:1f Starting key exchange to m
*dot1xMsgTask: Jun 27 11:45:34.855: 00:60:b9:0d:ec:1f Sending EAPOL-Key Message
.00.00.00.00.00
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.916: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.916: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.916: 00:60:b9:0d:ec:1f Stopping retransmiss
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.916: 00:60:b9:0d:ec:1f Sending the random G
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.916: 00:60:b9:0d:ec:1f Sending EAPOL-Key Me
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_R
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f 10.160.91.51 L2AUTHC
OMPLETE (4) DHCP required on AP c8:f9:f9:2b:69:20 vapId 2 apVapId 2for this clie
nt
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f Not Using WMM Compli
ance code qosCap 00
OMPLETE (4) Plumbed mobile LWAPP rule on AP c8:f9:f9:2b:69:20 vapId 2 apVapId 2
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f apfMsRunStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20
*Dot1x_: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) Adding Fas
t Path rule
  on AP c8:f9:f9:2b:69:20, slot 0, interface = 13, QOS = 2
*Dot1x_NW_MsgTask_7: Jun 27 11:45:34.922: 00:60:b9:0d:ec:1f Stopping retransmiss
*pemReceiveTask: Jun 27 11:45:34.923: 00:60:b9:0d:ec:1f 10.160.91.51 Added NPU e
*apfMsConnTask_6: Jun 27 11:45:46.092: 00:60:b9:0d:ec:1f Reassociation received
from mobile on AP 3c:ce:73:f9:06:50
*apfMsConnTask_6: Jun 27 11:45:46.092: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
licy.c:1697)
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) C
licy.c:1864)
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f Applying site-specific
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f Applying Local Bridging
erface 'pvoz'
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f processSsidIE  statusCo
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f processSsidIE  ssid_don
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f STA - rates (8): 139 22
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f suppRates  statusCode i
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f STA - rates (10): 139 2
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f extSuppRates  statusCod
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f Processing RSN IE type
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f pemApfDeleteMobileStati
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) D
eleted mobile LWAPP rule on AP [c8:f9:f9:2b:69:20]
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f Updated location for st
ation old AP c8:f9:f9:2b:69:20-0, new AP 3c:ce:73:f9:06:50-0
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f apfMsRunStateDec
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f apfMs1xStateDec
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f pemApfAddMobileStation2
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f 10.160.91.51 START (0)
Initializing policy
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f 10.160.91.51 AUTHCHECK
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_REQD
(3) DHCP required on AP 3c:ce:73:f9:06:50 vapId 2 apVapId 2for this client
*apfMsConnTask_6: Jun 27 11:45:46.093: 00:60:b9:0d:ec:1f Not Using WMM Complianc
e code qosCap 00
(3) Plumbed mobile LWAPP rule on AP 3c:ce:73:f9:06:50 vapId 2 apVapId 2
*apfMsConnTask_6: Jun 27 11:45:46.094: 00:60:b9:0d:ec:1f apfPemAddUser2 (apf_pol
icy.c:268) Changing state for mobile 00:60:b9:0d:ec:1f on AP 3c:ce:73:f9:06:50 f
*apfMsConnTask_6: Jun 27 11:45:46.094: 00:60:b9:0d:ec:1f Scheduling deletion of
*apfMsConnTask_6: Jun 27 11:45:46.094: 00:60:b9:0d:ec:1f Sending Assoc Response
to station on BSSID 3c:ce:73:f9:06:50 (status 0) ApVapId 2 Slot 0
*apfMsConnTask_6: Jun 27 11:45:46.094: 00:60:b9:0d:ec:1f apfProcessAssocReq (apf
_80211.c:6290) Changing state for mobile 00:60:b9:0d:ec:1f on AP 3c:ce:73:f9:06:
50 from Associated to Associated
*pemReceiveTask: Jun 27 11:45:46.094: 00:60:b9:0d:ec:1f 10.160.91.51 Removed NPU
entry.
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Creating a PKC PMKID Cache
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Resetting MSCB PMK Cache E
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Removing BSSID c8:f9:f9:2b
:69:21 from PMKID cache of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Setting active key cache i
ndex 0 ---> 8
ndex 8 ---> 0
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Adding BSSID 3c:ce:73:f9:0
6:51 to PMKID cache at index 0 for station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:46.096: New PMKID: (16)
*dot1xMsgTask: Jun 27 11:45:46.096:      [0000] 2c de dd 37 b5 fb 3c 2d 0e a4 47
e2 fd 62 19 fe
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Initiating RSN PSK to mobi
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f dot1x - moving mobile 00:6
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Skipping EAP-Success to mo
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Found an cache entry for B
SSID 3c:ce:73:f9:06:51 in PMKID cache at index 0 of station 00:60:b9:0d:ec:1f
*dot1xMsgTask: Jun 27 11:45:46.096: Including PMKID in M1  (16)
e2 fd 62 19 fe
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Starting key exchange to m
*dot1xMsgTask: Jun 27 11:45:46.096: 00:60:b9:0d:ec:1f Sending EAPOL-Key Message
.00.00.00.00.00
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.172: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.172: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.172: 00:60:b9:0d:ec:1f Stopping retransmiss
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.172: 00:60:b9:0d:ec:1f Sending the random G
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.172: 00:60:b9:0d:ec:1f Sending EAPOL-Key Me
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f Received EAPOL-Key f
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f Received EAPOL-key i
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f apfMs1xStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f 10.160.91.51 8021X_R
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f 10.160.91.51 L2AUTHC
OMPLETE (4) DHCP required on AP 3c:ce:73:f9:06:50 vapId 2 apVapId 2for this clie
nt
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f Not Using WMM Compli
ance code qosCap 00
OMPLETE (4) Plumbed mobile LWAPP rule on AP 3c:ce:73:f9:06:50 vapId 2 apVapId 2
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f apfMsRunStateInc
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20
*Dot1x_: Jun 27 11:45:46.176: 00:60:b9:0d:ec:1f 10.160.91.51 RUN (20) Adding Fas
t Path rule
  on AP 3c:ce:73:f9:06:50, slot 0, interface = 13, QOS = 2
*Dot1x_NW_MsgTask_7: Jun 27 11:45:46.177: 00:60:b9:0d:ec:1f Stopping retransmiss
thank you!
Content for Community-Ad
August's Community Spotlight Awards
