Highlighted
Beginner
help ...5520 wlc cannot change hostname
Hi experts,
i needed to change the wlcs hostnames but to my surprise i simply cannot change it. i attached the message when im trying to do it. pls help. thanks in advance!
12 REPLIES 12
Highlighted
Hall of Fame Community Legend
Re: help ...5520 wlc cannot change hostname
What hostname are you changing to?
Highlighted
Beginner
system name of the wlc. the hostname im using met the criteria already but still im not able to change it.
Highlighted
Hall of Fame Master
You changing this from the cli or the gui? That should work fine.
-Scott
Highlighted
Beginner
hi, i tried both gui and cli but having the same message. and i couldnt change it
Highlighted
Beginner
the version im using is 8.10.112.0.
Highlighted
Hall of Fame Master
Post the output from the cli and configure the hostname with a different name
-Scott
Highlighted
Beginner
ok seems like the wlc doesnt want an underscore.... i tried below and it accepted the TESTNAME. but weirdly the hostname configured during the initial configuration has an underscore on it.
(Cisco Controller) >config sysname DC1_01A_WLC1
Hostname is not compliant to RFC !.
Hostname can contain max of 24 characters namely Upper/lowercase letters,numbers,dot,hyphen.
Hostname should always start with an alphabet and should not end with '.' or '-'.
(Cisco Controller) >config sysname TESTNAME
Warning! System name change will disrupt the existing RF Grouping.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.10.112.0
RTOS Version..................................... 8.10.112.0
Bootloader Version............................... 8.3.15.177
Emergency Image Version.......................... 8.2.166.0
OUI File Last Update Time........................ Tue Feb 06 10:44:07 UTC 2018
Build Type....................................... DATA + WPS
System Name...................................... TESTNAME
System Location..................................
Beginner
ok seems this image doesnt accept underscores. initial setup hostname has underscore but not upgraded yet to 8.10.112
Highlighted
The screenshot posted specifically states "Hostnames can contain max of 24 characters namely upper/lowercase letters, numbers, dot and hyphen".
Nowhere does it state that underscores are allowed/accepted.
Highlighted
Beginner
and why there is this restriction on this new firmware? who ever doing the wlc os programming should just leave the hostname modification alone. its just a hostname. we did ap priming for 9aps already, what if we did that for 100 of aps, that will be pain in the arse to redo it.
Highlighted
Hall of Fame Master
Well that is a feature request you can bring up to Cisco. As far as priming AP’s, you can automate that or build a script to easily change that.
-Scott
Highlighted
Hall of Fame Master
Yeah... it does state what is allowed and what isn’t. Use a dash ‘-‘ if you really need a delimiter.
-Scott
Content for Community-Ad
