03-14-2012 09:24 AM - edited 07-03-2021 09:47 PM
I bought 6 air-lap1042n-a-k9 for our business. They are mounted. I bought a Cisco POE switch for them. I hooked them up and realized they needed a Wireless LAN Controller. I have never dealt with these before. From my research, I need to buy AIR-WLC2106-K9.
My question, Can I just connect my POE switch to the LAN Controller to configure all 6 access points that are connected to the POE switch?
03-14-2012 09:27 AM
acutally, I would go with a 2504-5 with a 5 AP license upgrade. Believe the 21xx are going EOL soon if not already.
but yes, once the WLC is configured you just connect it to the switch.
Steve
03-14-2012 09:28 AM
Great thanks for the reply. I was worried I needed to find a 6 port POE lan controller.
03-14-2012 10:03 AM
You can also try to convert AP to autonomous
03-14-2012 02:03 PM
Errrr ... The OP purchased six (6) WAPs.
03-14-2012 02:08 PM
yup. 2504-5/15/25/50. but the upgrade comes in 5. so base 2504-5, +5 AP upgrade to 10 AP total capacity.
Steve
03-15-2012 01:53 PM
Ok. Thanks.
