I have a test network with a Cisco 2504 WLC and 1142N access points. I am just beginning to study for the Wi-Fi certification. I have a connection to 2504 WLC. AP is joined to WLC. When I connect to the Wi-Fi, it says, "connected without internet".
I am new to this, but I think the problem is in the router configuration. The Wi-Fi vlans are 20 & 30. A friend of mine configured the 2911 router Cisco router. He is a Cisco technician. Can someone please take a look. I have included the 2911 switch config and the 291 router config.
Thanks.
2911 switch module configuration
new_switch5_sd#show run
Building configuration...
Current configuration : 5957 bytes
! No configuration change since last restart
version 12.2
no service pad
service password-encryption
hostname new_switch5_sd
boot-start-marker
boot-end-marker
enable secret 5 $1$Ct05$EOtswY8i0HaZWt63.tWrU.
username clay password 7 14141E0A15
no aaa new-model
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
no ip domain-lookup
crypto pki trustpoint TP-self-signed-1965366656
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1965366656
revocation-check none
rsakeypair TP-self-signed-1965366656
crypto pki certificate chain TP-self-signed-1965366656
certificate self-signed 01
30820247 308201B0 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31393635 33363636 3536301E 170D3933 30333031 30303031
30355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 39363533
36363635 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100D650 6202A5F1 7FC8D195 42902F5D CF6553E9 D5834975 0E1BA7B2 2118BF58
D72F2A57 FE59271D FB1002A7 29F6CDCE F678C004 AFA8480D 0A7017B2 5A724449
E7DDBB67 5677E1E2 ADE1A73F 40B31160 9541313F 74DDFFEE 1B7E588D 3B4475B6
34924AD8 63279762 F4672C35 276E6FF3 2787EBAF 0DFB694E E2A97B0F 39500C07
F2130203 010001A3 6F306D30 0F060355 1D130101 FF040530 030101FF 301A0603
551D1104 13301182 0F6E6577 5F737769 74636835 5F73642E 301F0603 551D2304
18301680 14C86BC8 84B565A8 B6629EAC A7EB5E0F 02D97FB9 B7301D06 03551D0E
04160414 C86BC884 B565A8B6 629EACA7 EB5E0F02 D97FB9B7 300D0609 2A864886
F70D0101 04050003 8181001B DEC049C1 988DEA19 D5BA7CFA EC128B41 6D6AEBA1
606FEBE1 01686393 B3B5179F 44046CA8 613AA147 55E00B10 EFD838A8 03A90754
77CF915B C8846047 316D8112 BE0F8504 1DE05F0B E06678B2 725F78B4 4D9E57E6
B4817ABC F0CDC4B5 CF3D0DE9 4C967DD2 359B7E4B 9D49F0A0 3D1AAC05 BD43C0B8
38A4B3FE 6C286743 3EFCC9
quit
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
interface FastEthernet0/2
description 5 subnet interfaces
switchport access vlan 5
switchport mode access
spanning-tree portfast
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
description access port wifi vlan 20 ONLY NEEDS 1 WLAN/VLAN ON PORT
switchport access vlan 20
interface FastEthernet0/12
interface FastEthernet0/13
description interface for vlan 13
switchport access vlan 13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
switchport access vlan 70
interface FastEthernet0/18
switchport access vlan 80
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
description trunk port to 2911 rtr int gi0/0
switchport mode trunk
interface FastEthernet0/22
interface FastEthernet0/23
description trunk port to 2504 WLC 192.168.5.4
switchport trunk native vlan 5
switchport trunk allowed vlan 5,20,30
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan5
ip address 192.168.5.2 255.255.255.0
no ip route-cache
interface Vlan13
description vlan interface for vlan 13
ip address 192.168.13.2 255.255.255.0
no ip route-cache
interface Vlan20
ip address 192.168.20.2 255.255.255.0
no ip route-cache
interface Vlan30
ip address 192.168.30.2 255.255.255.0
no ip route-cache
interface Vlan80
ip address 192.168.80.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.5.1
ip http server
ip http secure-server
ip sla enable reaction-alerts
line con 0
exec-timeout 0 0
logging synchronous
login local
speed 115200
flowcontrol software
line vty 0 4
login
line vty 5 15
login
end
new_switch5_sd#
2911 router config
version 12.2
no service pad
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip domain-lookup
quit
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan5
no ip route-cache
interface Vlan13
no ip route-cache
interface Vlan20
no ip route-cache
interface Vlan30
no ip route-cache
interface Vlan80
no ip route-cache
ip http server
line con 0
exec-timeout 0 0
logging synchronous
login local
speed 115200
line vty 0 4
login
line vty 5 15
login
end
2911 Router configuration
new_switch5_sd#
New-Router#show run
Current configuration : 3648 bytes
! Last configuration change at 11:51:08 UTC Wed Jan 27 2021 by clay
version 15.3
hostname New-Router
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
enable secret 5 $1$wdYE$6FujLqChJqz7QKhnFaDq5.
no aaa new-model
no ip domain lookup
ip domain name photonics.org
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FJC1910A1VA
hw-module sm 1
username clay password 0 clay
redundancy
ip ssh version 2
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description ***Inside-Interfae***
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.5
description INSIDE INTERFACE
encapsulation dot1Q 5
ip address 192.168.5.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/0.13
description subinterface for vlan 13
encapsulation dot1Q 13
ip address 192.168.13.1 255.255.255.0
ip helper-address 192.168.5.7
ip nat inside
interface GigabitEthernet0/0.20
description subinterface for vlan wlan 20
encapsulation dot1Q 20
ip address 192.168.20.1 255.255.255.0
interface GigabitEthernet0/0.30
description subinterface for vlan wlan 30
encapsulation dot1Q 30
ip address 192.168.30.1 255.255.255.0
interface GigabitEthernet0/0.70
description subinterface for VOIP phones
encapsulation dot1Q 70
ip address 192.168.70.1 255.255.255.0
interface GigabitEthernet0/0.80
description vlan sub interface for 5508
encapsulation dot1Q 80
ip address 192.168.80.1 255.255.255.0
description ***Connected-to-LinkSys***
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface GigabitEthernet1/0
ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet1/1
description Internal switch interface connected to Service Module
no ip address
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 101 permit ip 192.168.6.0 0.0.0.255 any
access-list 101 permit ip 192.168.20.0 0.0.0.255 any
access-list 101 permit ip 192.168.30.0 0.0.0.255 any
access-list 101 permit ip 192.168.13.0 0.0.0.255 any
access-list 101 permit ip 172.16.10.0 0.0.0.3 any
access-list 101 permit ip 192.168.80.0 0.0.0.255 any
access-list 101 permit ip 0.0.0.0 255.255.255.0 any
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 0 0
logging synchronous
login local
transport input ssh
scheduler allocate 20000 1000
end
New-Router#
You have 2 Routers - do you have any high level diagram how they connected and your internet breakout connection.
and where the user connected what IP range user not getting internet ?
From router you connected to Internet able to ping 8.8.8.8 ?
Thank you. This is a test network. I have one router and one switch. It's a 2911 router with a switch module. Yes I can ping 8.8.8.8.
can you can post current running config after changing settings, are you able do same ping from end device ?
I have not changed any settings.
The access point cannot reach default gateway 192.168.1.1
I think problem is in router configuration.
Post the current router config - what is the Wireless IP range ?
This is a test network. Very simple. The access points get IP from DHCP controller. DHCP has issued correct IP address to access point. 192.168.20.14
Access point and WLC can not get to default gateway192.168.1.1 IP address of WLC is 192.168.5.4. I think problem is in access list. I am not sure.
This is router config
New-Router#show run
Current configuration : 3831 bytes
! Last configuration change at 09:04:05 est Wed Jan 27 2021 by clay
! NVRAM config last updated at 10:10:13 est Wed Jan 27 2021 by clay
version 15.3
hostname New-Router
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone est -5 0
no ip domain lookup
ip cef
no ipv6 cef
hw-module sm 1
redundancy
ip ssh version 2
interface Loopback0
no ip address
shutdown
no ip address
duplex auto
speed auto
ip nat inside
ip nat inside
ip address dhcp
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
clock rate 2000000
no ip address
shutdown
clock rate 2000000
no ip address
interface Vlan1
no ip address
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
login local
line aux 0
line 2
no exec
stopbits 1
line 67
no exec
transport input all
stopbits 1
line vty 0 4
exec-timeout 0 0
logging synchronous
login local
transport input ssh
ntp server 192.168.5.7
end
New-Router#
