02-20-2020 11:52 PM - edited 07-05-2021 11:44 AM
after WLC 3503 Update to 8.10.112.0 is the Hostname Field Unknow. What is the Issue? In 8.5.140. we´ve got no Problem with that. Can Some one Help?`
Thanks a lot.
02-21-2020 12:44 AM
- Not sure about the cause, but is it possible to set the hostname again ?
M.
02-21-2020 06:08 AM
I think he means the hostname column under client view. I had the same issue with ME 8.10.112.0, local profiling seems to be broken. I needed to downgrade to 8.10.105.0 to make it work again.
02-24-2020 12:06 AM - edited 02-24-2020 12:08 AM
02-24-2020 12:31 AM
- Go to WLANs tab \ WLAN ID \ Advanced look for Local Client Profiling and check the box for HTTP profiling , and or make sure it still enabled. It could be that the upgraded flipped it. Repeat for other Wlan's if needed.
M.
02-24-2020 01:13 AM - edited 02-24-2020 01:13 AM
Hi Marce,
thanks, but I checked allready this Points. DHCP & HTTP Profiling is checked. DHCP Addr. Assignment is checked too.
02-24-2020 01:32 AM
- Could you try flipping the settings yourself off/on , see if that makes any difference.
M.
02-24-2020 02:41 AM
no positive result. If I switch the Controller Config Boot Image to 8.5.140.0, than everything works! Buggy 8.10.112.0?
02-24-2020 03:29 AM
02-24-2020 07:49 AM
I would try previous 8.10.105.0 release, it is working fine here. Local profiling is defective in 8.10.112.0, didn't had the time yet to create a TAC case with Cisco to make them fill a bug report.
