how can i configure air-ap1852i( like a access point)
Hello All,
i have a cisco air-ap 1852i -E-K9 and i cant go to web interface , and in console interface i stack in (cisco controller) >
some one help me pls
thank you
14 Replies 14
Scott Fella
Have you looked at the configuration guide at all? Depending on what image your ap is on and if it was previously configured or not, you might have to configure the ap from the CLI before you can get access to the UI. When you have console connection, reboot the ap and look to see what image the ap has, this can tell you what you will have to do next to configure the ap. Look at these links: https://www.cisco.com/c/en/us/support/wireless/aironet-1850-series-access-points/products-installation-and-configuration-guides-list.html
-Scott
Hello Scott Fella,
yes i have read all configuration guides but i can't understand the probleme , for infomation i have 8.10.122.0 image , normaly this cisco ap 1852i show a SSID Ciscoairprovision but i cant find that, am gonna join a picture explain when i stack
thank you alote for your answer
Sometimes that doesn't really work, the Ciscoairprovisioning SSID. I have only been able to see them on brand new AP's, but when an ap is converted, it seems like that doesn't show up. You would have to configure the AP using the CLI until you get http/https access to the AP. Don't waste time trying to get the provisioning SSID if you have already tried factory resetting the ap and you still don't see it.
-Scott
Hello Scott Fella
so how can i configure the ap using CLI : pls can you send me commands or tutoriel expalin how to get http/https?
Thank you alot
Configure the management interface properly on it and then configure the switchport as well.
How to configure mgmt interface:
config interface address management <ip-addr> <ip-netmask> <gateway>
config interface quarantine vlan management 0
Switchport where AP is connected: (Example)
interface GigabitEthernet1/0/37
description » Connected to AP «
switchport trunk native vlan 122
switchport trunk allowed vlan 10,20,122
switchport mode trunk
Dont forget to rate helpful posts
hello Sandeep Choudhary
i cant put this commands in CLI( console), whene i turn on my cisco 1852i go directly to conlroller config ( Cisco controller > ). for infomation i dont have a controller , so i need just to turn my cisco 1852i to a normal Access point can i do this ?
Thank you a lot
Try to go in AP Console
Controller> ap  (Type ap and press tab) and check
Rgds/Sudhir
Hello  sudhir.gupta1
this command just logout and nothing new , watch the screen shot
It will only work as Mobility express AP/WLC.
Check the guide to deploy Mobility express:
https://www.packet6.com/deploying-cisco-mobility-express/
https://www.lookingpoint.com/blog/mobility-express
There are a lot of videos and blogs out in the internet for Mobility Express. Just review a few different ones and that should help you get started. Mobility Express to me, isn’t easy to get working and that is why Cisco moved away from Mobility Express on the newer access points. Take some time and look at the guides, videos and blogs because there are multiple ways to get ME working.
-Scott
Hello Scott Fella,
yes exactly i watch alot of videos and blogs, but all most videos and blogs use SSID method, i keep searshing
Thank you alot
Hello Sandeep Choudhary
this URLs tell to install cisco with SSID "Ciscoairprovision" but in my cisco SSID not showing,
thank you for the answer
check the swicthport config where AP is connected.
It must be configured in this way:
interface GigabitEthernet1/0/1
description **Master ME AP**
switchport trunk native vlan 10
switchport trunk allowed vlan 10,20,30
Hellloo ,
Thank you so much sandeep Choudhary, now i can run myc cisco 1852i like AP
thank you alot
