12-02-2014 11:29 AM - edited 07-05-2021 02:03 AM
I'm trying to replace a WLAN controller with a new one. One WLAN is configured with WPA-PSK. Nobody seems to know the key that was used.
Anyone know if there is a way to extract the encrypted key out of a controller and put it into the new WLAN Controller?
Thanks in advance.
Solved! Go to Solution.
12-02-2014 12:57 PM
Na... The WLAN move was pretty easy ..
I would open a ticket with vocera about this issue and tell them about the hash .. They should be able to do it ..
12-02-2014 11:57 AM
No can do ...
https://supportforums.cisco.com/discussion/11364566/view-psks-wlans-wlc
However, if any users are on a MAC Book and has iCloud enabled you can see the key under the "keys". If you have a windows 7 box and uses the native supplicant you can expose the key on the supplicant ..
12-02-2014 12:16 PM
This just happens to be a Vocera badge WLAN. No clients other than badges...
12-02-2014 12:19 PM
If vocera can get to the hash in the vocera server you might be able to get the key. We had this problem. We ended up setting up a new WLAN and doing a push to the badge and moved them to the new WLAN with a new key ..
12-02-2014 12:50 PM
Got that hash.
That sounds extremely painful - setting up new WLAN, etc.
12-02-2014 12:57 PM
