435
Participant
how i can AP is AIR-AP1815I-I-K 9 ???,
N(Cisco Controller) >show ap summary
Number of APs.................................... 2
Global AP User Name.............................. AP-TEST
Global AP Dot1x User Name........................ Not Configured
Global AP Dot1x EAP Method....................... EAP-FAST
* prefix indicates Cisco Internal AP
AP Name Slots AP Model Ethernet MAC Location Country IP Address Clients DSE
*AP780C.F0DB.2A90 2 AIR-AP1815I-I-K9     78:0c:f0:db:2a:90    default location    TN   1.1.1.134 0 [0
AP28AC.9E89.48E0 2 AIR-AP1815I-I-K   28:ac:9e:89:48:e0       default location      1.1.1.25 0 [0
when i configured the AP28AC.9E89.48E0  with the same configuration  code country  TN as AP780C.F0DB.2A90 ,
teh AP don't accpted the code country and tell me AP name invalid :
config ap disable .......
config ap country TN ......
 Other RQ:  how i can allow AP28AC.9E89.48E0  is AIR-AP1815I-I-K 9  ?????????,
1)  Why AP1 with AIR-AP1815I-I-K 9  and AP 2 AIR-AP1815I-I-K  ?????, :
2) WHY AP2 don't accpet any country ?,, what i can do with AP2
3) AP1 version 8.8.100 and AP2 8.8.100
thanks in advance
Everyone's tags (1)
17 REPLIES 17
Participant
Re: how i can AP is AIR-AP1815I-I-K 9 ???,
Why AP have AIR-AP1815I-I-K  not AIR-AP1815I-I-K9  ??????,
what is solution thta allow AP to be as AP 1?
AP 1  8..8.100 and backup 8.8.111
then  what IOS that allow problem AP to be as AIR-AP1815I-I-K9!!
Everyone's tags (1)
VIP Advisor
We can see two types:
AIR-AP1815i-x-K9 - controller-based
AIR-AP1815i-x-K9C:   Mobility Express
I´ve never see without the K9. What do you see if you look through the Web interface instead?
The ‘ x ’ can be any one of these supported regulatory domains: A, B, C, D, E, F, H, I, K, N, Q, R, S, T, Z.
Which means, Tunisia is on the list.  My suspicion is that this AP may have some problem and may need to be replaced.
-If I helped you somehow, please, rate it as useful.-
Participant
I give you a print screen about the two acces point : AP 1: moblity express and AP2 : acces point
2) when i try with new AP or any AP to be the same code country as ME ( AP1 °)  and give the command :
config 802.11a disable network
onfig 802.11b disable network
config country
config 802.11a enable network
config 802.11b enable network
config ap disable  ......( name AP tell me is invalid name ) but i put the same name AP !!!?,,,,,
show ap summary   :  alaway AP1( ME 1815I) is good and AP 2 do not accept the command  !!???,
So what do you think about other AP to be the same code country !!! and accpet the command
config ap disable ....( name AP)
ME : vesrion 8.8.100 and other AP 8..3.111 and 8.8.100 !!
Everyone's tags (1)
Participant
Please , i wait a solution for this problem
config ap {{ enable | disablecisco_ap   (  Tell me  Name of the Cisco lightweight access point.  in nvalid )  !!!?,AP28AC.9E89.48E0  in invalid !!!!!
thanks
Everyone's tags (1)
Participant
Plese you can read my messages properly about outbout of this command and configuration   and say me  what solution that i can  to take ??
Everyone's tags (1)
Participant
If you have a solution then thanks to help me else , do not spend the time to answer me  anything and heading to other discus!!!
please so can  you  help me !!!Thanks
Everyone's tags (1)
Hall of Fame Community Legend
Please refer to CSCuw56127 and change the controller country settings to either Egypt or Israel.
Highlighted
Participant
AP Name Slots AP Model Ethernet MAC Location Country IP Address Cl ients DSE Location
*AP780C.F0DB.2A90 2 AIR-AP1815I-I-K9 78:0c:f0:db:2a:90 default location   IL   1.1.1.134 1 [0 ,0 ,0 ]
AP2 2 AIR-AP1815I-I-K 28:ac:9e:89:3d:b8 default location 1.1.1.168 0 [0 ,0 ,0 ]
(Cisco Controller) >config ap disable AP2
Invalid parameter specified.
(Cisco Controller) >config ap country IL ?
<Cisco AP> Enter the name of the Cisco AP.
all Configure all the Cisco APs.
(Cisco Controller) >config ap country IL all
To change country code: first disable target AP(s) (or disable all networks).
Changing the country may reset any customized channel assignments.
Changing the country may reboot disabled target AP(s).
Are you sure you want to continue? (y/n) y
!!Warning!! Cannot change Country code on Universal APs.
AP Name Country Status
AP780C.F0DB.2A90 IL enabled (Disable AP before configuring country)
(Cisco Controller) >config ap disable ?
what is a solution can AP accpet country !!????,,
Everyone's tags (1)
Please read THIS.
Participant
i put ISARIL but ALSO AP 2 1815 don't accpeted any code country becuse the command
Incorrect input! Use 'config ap [enable/disable] <Cisco AP>'
(Cisco Controller) >config ap disable AP28AC.9E89.3E10
Cisco AP name is invalid.
AP Name Slots AP Model Ethernet MAC Location Country IP Addr ess Clients DSE Location
*AP780C.F0DB.2A90 2 AIR-AP1815I-I-K9 78:0c:f0:db:2a:90 default location IL 1.1.1 .134 0 [0 ,0 ,0 ]
AP28AC.9E89.3E10 2 AIR-AP1815I-I-K 28:ac:9e:89:3e:10 default location 1.1.1. 47 0 [0 ,0 ,0 ]
i put the same name of acces point but tell me  invalid !!!
So please help me that allow ALL AP joind to ME 1815 !
Everyone's tags (1)
Config is disabled because the command is only valid when entered into a controller.
If the child AP is CAPWAP and has the Regulatory Domain of "-I" then wait for the ME to boot up with Israel or Egypt.
Participant
cisco AIR-AP1815I-I-K9 ARMv7 Processor rev 5 (v7l) with 1016100/788364K bytes of memory.
Processor board ID FGL2209B3S9
AP Running Image : 8.8.100.0
Primary Boot Image : 8.8.100.0
Backup Boot Image : 8.8.111.0
Primary Boot Image Hash: 5d18bf2dd83eb927f5db60ef46005440dd0a1c410284f278775b5e34a17cb0156d02e7976865236e7cb8ac69c2729979c1aa78d0cb2832298ce41c691ed9ce62
Backup Boot Image Hash: b74c97255daf86219bbab6c75d82d9de9b0f5bc4604b407288c5702261bd86597c9417cb6f67ebe5ba092274a814d5ef80504da416d1764168c7f162e9067a0d
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio FW version : ce271f0c3bd6087f274af2d1d72e15b7
NSS FW version : not available
Base ethernet MAC Address : 28:AC:9E:89:3D:B8
Part Number : 0-0000-00
PCA Assembly Number : 074-105850-02
PCA Revision Number : 0
PCB Serial Number : FOC22063AD0
Top Assembly Part Number : 074-105850-02
Top Assembly Serial Number : FGL2209B3S9
Top Revision Number : A0
Product/Model Number : AIR-AP1815I-I-K9
AP2#show capwap client config
AdminState : ADMIN_ENABLED(1)
Primary controller name : AP-TEST
Primary controller IP : 1.1.1.73
Secondary controller name :
Secondary controller IP :
Tertiary controller name :
Tertiary controller IP :
ssh status : Disabled
ApMode : Local
ApSubMode : None
Link-Encryption : Disabled
OfficeExtend AP : Disabled
Discovery Timer : 10
Heartbeat Timer : 30
Syslog server : 255.255.255.255
Syslog level : errors
AP join priority : 1
IP Prefer-mode : Unconfigured
CAPWAP UDP-Lite : Unconfigured
AP retransmit count : 5
AP retransmit timer : 3
AP lsc enable : 0
AP Policy Tag : UNKNOWN
AP RF Tag : UNKNOWN
AP Site Tag : UNKNOWN
AP Tag Source : 0
AP lsc reboot cnt : 0
AP lsc max num of retry : 0
SwVer : 8.8.100.0
spamStatTimer : 30
Led State Enabled : 1
Primed Interval : 0
AP ILP Pre-Standard Switch Support : Disabled
IPv4 TCP MSS Adjust : Disabled
IPv6 TCP MSS Adjust : Disabled
LinkFailure : 0
SpamReboots : 101
ApCrashes : 0
AP VLAN Tag status : Disabled 0
AP Power Injector : Disabled
Slot 0 Config:
Radio Type : RADIO_TYPE_80211bg
Radio Mode : Local
Country code :
Country ISO Code :
CleanAir Enable State : Disabled
Channel : 1
Automatic Config : 1
Channel Width : 20
Current Transmit Power : 1
DiversitySelection : Diversity Enabled
HT Rx Antenna Selection : 3
HT Tx Antenna Selection : 3
Antenna Band Mode : Antenna Sector B
Antenna Selection : Internal Antenna
Load Profile
RF Busy Threshold : 10
Clients Threshold : 12
Bytes/Second Threshold : 1000000
--More-- [*02/12/2019 10:26:27.4099] Image d
FOR Moblity express i changed   Egypt.
AP Name Slots AP Model Ethernet MAC Location       Country      IP Address Clients DSE Location
*AP780C.F0DB.2A90 2 AIR-AP1815I-I-K9 78:0c:f0:db:2a:90    default       location     EG    1.1.1.134 0 [0 ,0 ,0 ]
I wait several hours but  others acces point don't recieve the country code  and also in interface web same output as CLI .
1) i put this command in controller for other acces point to be same code country as ME !!!
So why i still in boucle problem . Please , i would the team of this group give me solution about others acces point code country !
thanks
Everyone's tags (1)
Can you try and force the AP to boot 8.8.111.0?
Participant
I put
config boot path 1
reload :===> same primary version
and also i try
config boot path 2
so please what command that force the AP to boot with 8.8.111 !!
thanks in advance
Everyone's tags (1)
Content for Community-Ad
August's Community Spotlight Awards
